Dave Wilkinson
ORIGINAL: dirtgod
OK chaps hey presto i now have heating but how do i get the thing to blow cold air its a non air con cheers
If you turn the temperature selector to the blue dot the CCU SHOULD close the hot air entry into the mixing chamber, leaving just the cold air to flow into the cabin. However, my emphasis on "SHOULD" is no mistake. The servo motors are known to suffer problems such that they will not operate the flaps as expected.
The other common problem is that the flexible tubes connecting the sill tubes to the mixing chamber disintegrate and allow hot air to escape into the footwell. No amount of fiddling with the CCU controls will have any effect on this problem. Replacment of the tubes (approx £10 each at OPC) is the only solution.
Dave
