ORIGINAL: northo
I am having similar problems with my 91 S2. Have had all connections etc checked and they seem to be fine. Car was running fine after the check, but has since once, and only once, not restarted when hot. Definately not the battery, as it is new, and the car has just been serviced, so I don't think it is the fuel filter. Very frustratiing and wierd.
Someone has suggested that I get a new DME relay. Coyuld that be the problem?
If it turns over at normal speed then I would suspect the temp sensor on the head to have failed, or for fuel to be draining out of the fuel rail the remainder evaporating and causing a 'air' lock
If it turns over slowly when hot, starter heat shield, earth or power cable with hot oil soaking into it
Dme relay always worth a shot - a spare in the glovebox is always worthwhile.
Tony
