Hurrah my sills are better than I thought
- Thread starter Diver944
chrisdenton
Have you considered offering your services to us less tallented owners? and if so what would you charge. I'm sure I'm not the only one who, for a reasonable fee,wouldnt jump at the chance of a proffesional to sort out minor rust problems.
Diver944
PRJ
ORIGINAL: Diver944
The time consuming preparation, rust treatment and application of the Stoneguard could easily be done DIY. Then you could take the car to a local bodyshop to spray the body colour. I'm sure this could be done for around £150 a side.
Perhaps even less than that figure too. I'm picking the car up tomorrow from my local bodyshop where they've done the whole lot (rust removal, prep, stoneguard and paint) for £100 a side.
Diver944
ORIGINAL: PRJ
Bother - I could have had the weekend off [
Dont foget to praise them to the skies and give contact numbers if you're happy with the job, I think lot of us will need this sort of work as time goes by.
PRJ
ORIGINAL: Diver944
Yeah I will do. They said over the phone they look superb now, but I'm notoriously picky, so we'll see [
I spent ages looking for a bodyshop that I felt comfortable using and who didn't charge the earth and on the face of it these guys seem pretty good. Hopefully I won't be picking up some 2-tone monstrosity tomorrow [
carlmthompson
I think you might have a point on getting the top coat done at a body shop - I have a one that I use for trade who work on around £50 per panel plus (ahem) VAT, which sounds like good piece of mind!
Is there any maximum length of time the Wurth stuff can be on before the topcoat is applied? Just wondering when to do this, based on the car being on stands for three months!
Alpine
ORIGINAL: sawood12
ORIGINAL: pauljmcnulty
Just as a thought, am I the only one who thinks that the plastic trims always look poorly fitted, and the cars are better without them?
Thanks.
Scott
I have just removed my plastic trims below my wings.
They are held in place by 3 bolts which screw through u-nuts, through lugs which hang down at the bottom of the wing.
You can adjust the fitting but moving the u-nut further up the lug, to get a tighter fit. Or it could be that the lugs have rusted away, so that they are just held on with 2 lugs, as in my case.
Its all pretty easy to do, just jack it up and have a look behind.
peanut
that would probably be the yellow stuff they use for double yellow lines lol[ORIGINAL: Alexw
what colour is this stuff?? I had the rear wheels off this weekend to clean them off properly and there was some sort of yellow rubbery stuff all over the inside of one of them, thought it might be waxoyl that somehow made its way there.
morris944s2john
Dinitrol is better because they have several products designed for different under bodywork protection. The 3125 cavity wax is the one to use inside sills. I would re-apply every other year as the wax eventually dries out/ is washed out/ dissapears mysteriously.
