sawood12
Nothing wrong with Waxoil though. I don't know how you can say one product is better than the other as they both are effective (probably both manufactured at the same factory). All the bodyshops i've ever spoken to say they use Waxoil, whether they are using Waxoil to describe a generic product because it is the one the average bod on the street is probably more familiar with I don't know. I gave my sills a good spraying with waxoil. You can thin it down thinners if you want to make sure it gets into all the nooks and crannies. The good thing about these products is that they drive out water and moisture so you can apply to a wet surface and the moisture will be driven away and the stuff provides active ongoing protection. Whether you use Dinitrol or Waxoil it doesn't really matter so long as you use something.
