Northern924
ORIGINAL: geoff ives
If you read the question you would understand the answer.
Geoff, sorry but I had to laugh that soudns like something from inside a fortune cookie [
ORIGINAL: 924nutter
Have you been sold the correct rotor arm? Do you still have the old one? Have you checked that the plug are actually firing, or are you asuming they aen't because the engine wont run? When you swapped 'stribs (sorry but this is the old world war two and, in my view, the correct abbreviation of distributor & whilst not wishing to cause offence, dizzie is too max pwer for me[:-]) did you check the position of the cam lobes? You can line up all the marks but be 180 out if you overlook checking to see if the lobes on no.one are in the 10 o'clock/ two o'clock position.
On this model 924 the only connection the fuel pump relay has with the igntion circuit is a feed from T1 on the coil to T16 ( I I RC) of the relay which disables the relay as a safety device if the coil signal drops out, for cutting pump feed in a 'stalled engine and ingnition on condition', preventing fuel from being pumped unnecessarily. In an accident, for example, with the driver disabled in some way and unable to cut the ignition, the pump would otherwise continue to feed, and you can use your own imagination as to how life threatening that would be if a fuel pipe ruptured in the engine bay spraying out fuel at 3 or 4 bar. Earlier models had a connection routed through the air metering unit via a terminal on the side of the casting which enabled the relay as soon as the flap lifted (i.e.engine sucking) and broke the connection.ORIGINAL: jr
Hi, you seem to have given the ignition system a good seeing to, might it be the fuel pressssure regulator on the fuel rail failing and flooding the engine? You can check this by fitting a pressure meter to the nose of the fuel rail and checking the pressure therein ( be careful if you unscrew the union on the rail as its got a spring behind it). It should be about 2 bars at tickover .
jr
ORIGINAL: 924nutter
By the way, if the resistance of the individual leads is around 6.7k ohms don't you think 1.4k is a bit low for a lead about half the length of no.4?
ORIGINAL: peanut
I still don't understand how you can have both a spark and fuel and not get some sort of ignition. ? you must be getting at least the occasional cough splutter or misfire .!
ORIGINAL: 924nutter
Peanut, on the 924 N/A it is possible to have a spark and fuel and still no cough or splutter. I speak from the bitter experience of a long afternoon in the compay carpark with a portable generator, a spark and gradually increasing mixture setting until I was getting a near hydraulic lock there was so much fuel. The only conclusion I could draw was that that a capacitor/ transistor combination within the module was allowing the spark to fire too soon or too weakly to set light to the fuel and make the engine run. What I do know for certain is that going from immobile to running as sweet as a die was achieved by changing the ignition module for a brand new one (£314 plus vat) without any other adjustments having been made.
ORIGINAL: 924nutter
The ICU is the igniton control unit and guess what, that's what it does. The ECU is the Engine control unit which on the 924S controls fuelling, and thus mixture as well as the ignition.
I knew you didn't understand the question[]
I understood that he quoted it as a 'TIU' that's what I didn't understand but then I don't claim to be a Technical Advisor. The thing on ebay was the usual alloy box that sits on the nears side inner front wing.
But what do I know?[8|]
