I've decided to buy a 944 Turbo
ORIGINAL: GlennS
ORIGINAL: Someguy
Is there anywhere that will re-upholster the front seats? Or is it possible to get new covers for them?
They're cream leather.
Peter
I recently had four panels (the bolsters) replaced on my driver's seat for a reasonable price. If you're within a sensible distance of Bracknell I can PM you the contact details for the guy who did it.
I would certainly be interested in those details too !
Thanks for all this information guys, I am also in the process of purchasing an '86 Turbo which I am beside myself with excitement about, it has an LSD but not the MO30, which given as I live on a farm with a 2 mile dirt road is no bad thing ! Watch this space, I'll drop some pics when I get it.
BTW, which was the Porsche mag that did the comparison between the 944 turbo and the 911 recently ? I'd love to get a copy.
Sean
ORIGINAL: Someguy
Thanks for all the comments. Currently I have the option of either a highish mileage car (130,000 miles) with a rough interior, well a rough drivers seat, but I figure that is to be expected from a 20 year old 130,000 mile car. And a good condition interior 75, mile car, which has been sitting for a while, and has sills I could put my hand through, though the rest of the body is sound and straight.
Without a moment's hesitation, get the high mileage car. Don't even consider buying the other one.
Rust is insidious, and once taken hold will be expensive and tedious to put right properly.
High mileage is a GOOD thing - these cars don't take well to sitting around.
And the low-mileage one didn't even start [:eek:] ... I rest my case, M'lud.
ORIGINAL: GlennS
ORIGINAL: Someguy
Peter
Please PM me too!
Thanks, Craig
ORIGINAL: DavidL
Oh and chances are any LSD that hasn't been rebuilt doesn't work anymore!
I dont understand why people say this, it's not true at all. Every 944 turbo I've driven fitted with a LSD worked just fine. Maybe you are expecting to much from them??
Yep mine works as I was grateful discover on a damp and greasy road a couple of weeks ago. AFAIK its never been refurbished though whether it works as well as one that has been I have no idea.
ORIGINAL: homesea
ORIGINAL: DavidL
I'll happily admit this is simply repetition of previous threads but the consensus of opinion was as above and that the diff would be more or less open by now.
Maybe someone was just unlucky, or not, as the case may be.
It is not that they don't work - it is that they don't work anywhere near as well as they should. Plate type LSD's wear, they rely on compression of the plates to achieve the locking, an as they wear they become less effective. The Porsche unit only had a relatively small number of plates which meant wear rate is high meaning that when the car was new you had a 40% locking diff. Now you've probably only go a 20% locking diff or less. Testing these things on wet grass isn't really a good test - it is on grippy tarmac that tests the LSD and at which point it locks.
All plate type LSD's will need refurbing at some point (the consensus from those who are experienced and in the know with the 944turbo unit is after about 40k miles to keep it as good as it should be). Aftermarket units have more plates - and are better as they lock on decel too.
??????My race car diff has done 180k,LSD still seems to function fine and it has never been touched as far as i can tell in its 10 inch thick history file,i dont think they wear out that much?My car has healthy power going through the rear aswell[:D]!
180k miles is alot for any component that rely's on friction to function - you'd not expect a clutch to last that long unless it had had a very easy life (the big unknown). These are consumable parts. I guess the big unknown is that you don't know how hard a life its had up until now - but guys on other forums who use their cars very hard seem to think the original Porsche unit is not that good and requires rebuilding after about 40k miles to maintain the 40% locking.
I must admit - I never missed an LSD on my car in the whole 6 years of ownership. I never found lack of grip to be a huge problem and only lost the inside rear wheel if I was pulling out of a junction (and with an LSD would have likely induced oversteer) or in wet conditions accelerating out of a roundabout and losing the inside rear wheel - again where an LSD would have likely induced oversteer. On the few trackdays I did I never felt I had to hold back on the accelerator because of the diff - maybe I was not pushing hard enough! Other than those small handful of occasions I never missed one.
GINAL: craig2105
ORIGINAL: GlennS
ORIGINAL: Someguy
Peter
Please PM me too!
Thanks, Craig
[/quote]
hiya glen i have sent you a pm for the guys details if thats ok. thanks and regards jason p
It sounds like I'll have a bit of work on my hands soon.
I think I know which one I'll be getting.
I'll keep you posted (and will probably be looking for places to get parts and seats).
Thanks again for the pointers.
Peter
ORIGINAL: homesea
I didn't realise all the later cars had the roll bars, torsion bars and brakes from the MO30 option.
Interesting that Porsche thought the higher spring rate of the torsion bars and roll bars would work with the normal shocks.
At least with the MO30 option you get the light weight wheels!
Isnt the option 'clubsport pack' not 'sport chassis' or these different things?
On the 90 cars they are not 'normal' shocks but turbo shocks without adjustment, In the handbook it claims the adjustment on the Konis are to compensate for wear and the sachs/boge are to the same rate. They are smaller diameter springs than the early turbo's as per the 968.
It was almost certainly a money saving exercise given the price of a late Turbo and the economic climate at the time.
Tony
hiya, i would defo go with the high? mileage model, shes just been run in with the mileage you taking her home with [if you go for that one], good luck anyway,,regards jason p
ORIGINAL: sawood12
I've always found an LSD in a rear drive car induced under-steer, due to the time it takes for the diff to return to the intial torque setting during cornering. Also you can't compare the engine clutch lifespan to a LSD clutch lifespan. But I'm with you that the 944 dosent need one, it's just nice to know you have one.
Avoid rust at all costs £££££££
Always buy on condition of the car and ignore what the mileometer says, it's not unknown for these cars to be clocked and who knows if the 75k car is in fact 175k or indeed 275k
Definitely go for the high mileage good body car. Remember, what rust you can see is only a percentage of what you can't. Seats are cheap/easy to replace/refurb and won't stop your car getting an MOT.
as others have said, mileage is largely irrelevant on a used well maintained car.
I have had one open diff 944t which was good, and three LSD cars, all have over 100k miles now and all the LSDs function perfectly. The wear rate and their performance deterioration is not linear.
The LSD makes a huge difference when overtaking, the traction is vastly superior, and dont be taken in by aftermarket product which need to slip to lock (viscous plates).
As Scott says the open diff car is good due to the transaxle weight distribution and relatively soft spring rates, plus his KW suspension, but if you want to be at the races (no pun intended) you need a limited slip.
good luck with your car
George
944t
So I took an S2(out of interest) and a turbo the 130,000 mile turbo for a spin. I was very disappointed by the turbo. It was far slower than the s2. It does need a good service (it cut out out on idle). Is it usual for them to loose this much power?
Would a service sort it out, or should I be looking elsewhere (or buying an s2)
Peter
I'll bet the turbo needs some better boost management - tired wastegate etc.. Did you get any sort of kick from the turbo? It should feel much faster through the midrange than an S2.
Did you notice how much boost it was developing (on the gauge 1 is effectively zero boost as it's atmospheric pressure.)
£500-£1000 'ish will see a massive improvement, maybe less if all it needs is a boost enhancer + chip
