Just a few bit's 'n' pieces of the latest build.
- Thread starter 333pg333
Yup, and it's a beautiful conversion let me tell you. This ain't no Rover 3.5L thing but I'll let Travis cover it off if he pops in again. He should start his own thread in here. Very nice example from what I've seen!ORIGINAL: Hilux
DVC, I`ve just noticed your signature.............
N/A 944 with 395 rwhp?? What engine, V8?
Diver944
ORIGINAL: DivineE
I'd probably keel over if my engine blew up a month after I got it back!
....and you know we'd all be there with knowing nods and lots of tutting if you did blow it up [
(just don't stick it into some barriers after six months [8|])
Thanks Ben.. Well the first rebuild way back in April, the engine lasted 3.5 days and it was on my birthday that I decided to take it for a long Sunday drive out to the countryside. Well about an hour out of Sydney I noticed some smoke in my mirrors but thought it must have been from the truck that I'd just passed. Pulled up at the next set of lights and I was engulfed in my own engine smoke. Shut it down, waited 1.5 hours by the side of the road to be towed back the 50 miles to the workshop. Top day thatORIGINAL: DivineE
I'd just like to say those are some of the nicest internals I've ever seen! Beautiful bit of engineering, hope it all works right this time round. I'd probably keel over if my engine blew up a month after I got it back!
Regards,
Ben
turned out to be....NOT! Anyway we're just waiting on the modified sump and the harness to get here to then put the motor in and dyno tune it. Another couple of weeks still, but I can almost taste the excitement building. Just to have the car back again will be almost strange.
Tell me, is your car running as a 3.2L now? Then there's Mike's as well and Lil just about to come back to life. So that's 3 x 3.2L in the UK now? I'm sorry if I missed any threads/posts on your build. Are they still in here somewhere as I'd be interested to read about it? Are the 3 cars basically the same? It's amazing to think that only a few years ago having a 2.7L or 2.8L was a rarity and now the 3.0L is semi-common around the world. With a bevy of 3.2's + some guy in the Carribean with a 3.4L and there's talk of even larger motors being built, it never ceases to amaze me that people are still pouring money into these long forgotten Porsches. Good thing too!
Hilux
That would be my main worry too.
Big reds or yellows, Quaife diff and bigger tyres on the rear necessary with all that power IMHO
A mates got a 1000bhp plus Cobra on 245 tyres (cant get anything bigger under the arches), drives it at 1/4 throttle as it spins the wheels whenever it wants to, 60-100 in under 3 secs etc etc and I`ll never ever get in it again. I had to ceremonially burn my underpants in the garden as no-one else would touch them after I got out of the car [&:]
sawood12
I'm sure I remember Rick Cannell saying he was thinking about getting traction control set up with his car. I wonder if he ever got anywhere with that?
Diver944
In the summer last year now fitted with 275 Kumho V700 soft tyres I could mash the pedal (on a straight) and have no problems whatsoever. Anyway, feathering the throttle is fun [
I certainly did enjoy the new levels of grip following the installation of the KW's and I thought that was one of the most common comments passed by everyone else who has done the same. I would think 255 Conti's in a cold UK winter aren't going to be helped by any setup though.[
sawood12
The biggest area I struggle with is coming off a roundabout on a dual carrigeway. There usually always seems to be a sharp hump as you turn off the roundabout and onto the exit. As the weight of the car is unloaded off the suspension as you go over the hump that is when the wheels start to spin. I either need to wait a few seconds before getting on the throttle or momentarily take my foot of the throttle to stem the spin. It is in these situations were i'd imagine if I had an LSD then oversteer would be induced - having said that it sounds like a Torsen diff wouldn't help in those situations as well as I believe they need both wheels to have grip to work properly or they just work like an open diff.
I think the best solution seems to be acreage of rubber.
Also I have used a 6 puk clutch disk and if you haven't tried one of these before you are in for a bit of a shock. Initially a light switch seems to have more compliancy! However even only driving it over 24 hours I'm getting used to it and actually like it. Most people would say that it destroys the 'streetability' of the car but it's 99% time only me in it and once you're up and running it's easy and actually better than the more stock ones. There is no real transition when changing up and down. Bang, you're in there, but it's not violent, just more efficient. I'm really looking forward to trying it on the track in 2 weeks time. More to come.[
Diver944
ORIGINAL: TTM
Why do you even post if you don't have pics of the completed thing to tease us with ... [][
Yeah, you big teaser.
I know what you mean about the running in process. My limited knowledge of these matters is that an engine is run in once the rings seal properly to the cylinder wall and all the bearings further down mate properly to the surface they run on. At this point there are no leakages and you will not burn any more oil and the engine is 'run in'. Old cars with big clearances would take quite a while to do this but modern cars are much tighter. Our 'blueprinted' hand built engines are even tighter on the tolerance and we are pretty sure mine was 'run in' after the first 200 mile oil change - it certainly burnt no more oil after that. However we painstakingly broke it in gently after that and I think it's only sensible to follow that sort of process.
Minimum of 1 bar spring eh? That's going to be some monster even on the base boost pressure [
appletonn
With all of that torque you are cultivating, I can't think of any tyre that would be able to contain it, no matter how wide![
Cold, greasy, wet tarmac + sudden onset of considerable boost = "slip sliding away..." sings quietly to self....[
sawood12
Earlier in your post you said you gave up on the MID wet sleeve option after your previous failure, i've been browsing on the Speedforce website (I should really get out of the habbit of doing that - my wish list keeps getting longer!) and they do an engine rebuild using wet Darton MID sleeves. Are these the same as what you were using?
Seems quite a good price on Speedforce considering the $-£ exchange rate at $8995. But that is only for the bottom end. You'd need a cylinder head and all the other stuff to get it running - not to mention the cost of shipping it back to the UK.
Also Patrick - can you get those deck plates for 2.5ltr stock blocks?
Diver944
ORIGINAL: appletonn
With all of that torque you are cultivating, I can't think of any tyre that would be able to contain it, no matter how wide![]
Sorry to takeover Patricks thread (but he's asleep over there in Oz anyway [
Nick it's actually very easily contained because there isn't a sudden rush of power at all. The power delivery is totally different to a standard 2.5 where nothing happens and then it all arrives in a bang. It is very, very similar to a normally aspirated S2, only it has even more urge from very low down and small throttle openings so you can feel that the power is always there. If you sense anything starting to get out of shape a mere feathering of the throttle will bring it back to normality, it is very, very docile if you need it to be.
When I was doing full power tuning runs on the Conti tyres in cold weather, then yes it would lose traction in an instant, but I don't drive like that normally and I think only those with a death wish would if they had a 400bhp RWD car on the road [
Patricks car wears even wider rubber on 18" rims and he has a very good KW suspension setup so I imagine he will have even more mechanical grip, and I think he will need it as ultimately he is going to have a very, very powerful engine at the front. I believe just getting his car running is the first stage of in a number of developments we are going to see on his car this year [8D]
Scott, yet they're exactly the same. If you want to email me I can give you more of an opinion, but I don't want to comment publicly much about them. Yes that deckplate you see in the pics is on a 2.5L motor. Mine has been taken out to 3.0L by Darton 'Dry' sleeves. They are a different proposition.
If I get a chance I'll dyno the car once it's run in and then again when we change out the turbo, headers, exhaust, ems etc. If I had the opportunity I'd like to do each one at a time so as to get a closer quantifiable number or worth of each change. It would be nice to own a dyno.[
