sawood12
ORIGINAL: Hilux
Just been pricing up the total cost of the KW installation and it has put the frightners up me!!
I`m not overly flush BUT I looked at aftermarket options (I personally dont like Koni`s) and the main option was to have my Mo30 rebuilt for circa £400 requiring new springs (35mm lowered type) required if yours are still the originals for circa £250?? (roughly £650 so far) then you`ll still need to reindex the TB so add £600 in parts plus labour for what is still an admirable set up but is still a soft road option.
The Ledas are circa £800 and you`ll still need to reindex the TB.
I chose the KW`s following UK/USA recommendations. They are inherantly reliable, completely rebuildable, fully and easily adjustable, non corroding and will transfer from car to car as required. They also have a residual value if sold on which is why I consider them v good value LONG TERM. I also consider that a knowledgeable purchaser (should I sell the car) will pay a small premium for my set up. If not I take it all off, lower the Mo30 and its no issue (It was especially a no-brainer when I drove, albeit briefly, Fens car where I was gobsmacked at how it completely transformed the feel and poise and balance of the car)
Thats my reasoning anyway as to why I saved and took the plunge.
I had it all fitted which will save a DIYer £500-£600 ish BUT even then it will have to go to a specialist to be set up properly which will cost £250+?? anyway as it needs to be driven and fine tuned and not just a static corner weight/laser set up (which is all that some specialists do)
I felt that going down another route I would be well over £1000 for the original set up anyway (albeit refurbished or brand new) and circa £1800 when you take into account that in my opinion you `should` fit 968 castor mounts at this stage, it will need professional setting up and the reindexing will possibly require new rear supports.
Note: I may have miscalculated a few bits but its no going back now..........[&:]
I agree and this is where I got to with my analysis. I have just underestimated the work involved in re-indexing the TB's and the fact that in all liklihood it will require the replacement of the rear TB tube mounts at near as damn it £100 each, so i've underestimated the total cost. I have decided I definately want to replace my rear TB's so even if I were to replace with standard the cost of the TB replacement would still be incurred. I don't see the point in refreshing the front shocks and springs and only the rear shocks. I've definately set my heart on KW's and in my head i'm 99.9% sold on them despite the cost but i'm still keeping my options open until the point I take the plunge!!
Also on the basis i'm planning on doing more track-days fitting standard is out of the question.
Back onto topic, where can you get your control arm ball-joints rebuilt? I thought there are only a handful of places that would take the plunge as it's a pretty delicate operation.
