Macan OPC launch party dates
Well Derek i am assuming the ride height of the show cars
Was normal and if that is so forget your wading but maybe
The airsup will go higher than normal.The other bad pointnfor me
was the view along bonnet .I am only 5.8 so,a bit short probably a
six footer will be fine .
IF it is on Q5 chassis it has a Hyundai look shell
The other low 4x4 was the new Merc GLA.
ORIGINAL: dereksharpuk
ORIGINAL: jonnyp1
Derek,
I am going to the Swindon launch
Jon, and anyone else going to the Swindon launch, let me know and touch base with me on the night. We will try and get a group photo for PP. So far we have Jon, me & Su and Alan Armstrong. 11 April.
Hi Derek
I'm hoping to make it to the Swindon launch evening.
David
As a current Q5 owner I'm interested in the Macan as a potential replacement, the Q5 has a 500mm water depth limit and 200mm of ground clearance I believe the Macan may be limited to 300mm for water depth and the same ground clearance, not that I'm planning on using it as a boat though [:D]
