MrDemon said:
TDT said:
My car is going into RPM next week for the final stage - MR KW 3-Way.
Can't wait to give it a try.
If you want to chat - let me know.
post up how that worked out for you ? and how long they had your car ! and still retuned it wrong !!!
I cannot rate RPM they seem totally clueless on how to set up cars ! please post a review so people can choose if they feel they want to visit them !!
it took them 3 attempts to set up my car and it's not right, Plus over charged me to death, Zero skills that outfit and don;t even seem to know the basics.
No wonder Manthey had to come and train them a few months back , but still have no clue.
In the end, I am happy with the set up... Will get its first track outing next week - but had a great run with a friend with a 718 GT4 this weekend and was very happy with the car - and he also drove mine as was impressed. 'Drives like a GT car should, so stable.. My car feels loose by comparison'.. was the quote.
He is off to get a geo this week so that will help him a lot - as he is getting some rear steer.
There was a bit of a communication break down with RPM initially - as I sent extra parts to get installed - Solid Castor pucks and Monoball LCA Inner for the Rear..
Castor pucks installed fine, but for the LCA Inners there was a bit of a mix up and the fault was partly mine... I thought that the MR LCA inners I had on the front were solid... they are not. They are from the 991.1 RS and larger but still rubber.
So they put by new solid ones on the front assuming thats where there were for, as that what you normally do... Things didn't fall in place line up on the rig as there are a different size.. they called me. We talked about what had been done... clarified and they put on the MR LCA inners back on and finished the setup. I had obtained the parts independently, without speaking with them first.
They did have a bit of difficulty with caster as the MR rig doesn't consider castor as adjustable caster/thrust pucks are not part of any of the MR kits - so they had to do some manual work to get this properly set.
This was all communicated, and I prize being transparent above all... and they were.
No additional charge for the labour or extra time on the rig as we shared the issue, discount for install of the extra parts as they were doing the full coilover setup up anyway.
So i have a set of Solid LCA inners for the rear on the shelf in the garage at the moment and we have Solid Fronts on back order from Porsche.
As it is, it gives me a chance to assess the KW coilovers in isolation and make a determination on if i want to go further or leave as is. Too many changes at once is an issue.
