Same here Ralph!
Brian
Brian
Brian, the GPF is now incorporated within the catalytic converters on the 718, 992 as there is no room for a separate GPF unlike for example the new Macan 2L which has a single GPF installed in the engine bay.BJ Innes said:Even at 70, I'm not averse to crawling about under cars. For the thick end of 50 years I've spent more hours than I care to imagine lying on my back staring at mechanical bits and pieces at close quarters.
Today was no exception. Heeding the advice of thread contributors JMR and Ray, I decided to tackle the rusty welds on the mufflers in my own garage. Armed with a Brillo pad, a container of warm water, a used kitchen scouring pad, sundry cloths, and my old faithful Autosol metal polish, I set about de-rusting the welds on the mufflers. Apart from complaints from my aching bones, access to the mufflers was extremely easy. Everything else was so clean with my car having done 500 dry miles. The job took me an hour and a half tops. Hopefully the Autosol will protect the rust from reforming for while. A photo attached for your interest.
While under the car I examined the GTS exhaust system carefully. No sign could be seen of the GPF filter, it must be tucked away close to the turbo installation. From my memory of examining my previous 718 CS exhaust system, this new GTS exhaust definitely looks different. The mufflers are smaller and the pipework leading to them seems of a larger diameter. This is why I am very interested in comparing pre-GPF 718 GTS mufflers with the units currently fitted to my car.
Brian
BigCat said:Brian, the GPF is now incorporated within the catalytic converters on the 718, 992 as there is no room for a separate GPF unlike for example the new Macan 2L which has a single GPF installed in the engine bay.BJ Innes said:Even at 70, I'm not averse to crawling about under cars. For the thick end of 50 years I've spent more hours than I care to imagine lying on my back staring at mechanical bits and pieces at close quarters.
Brian
BJ Innes said:While on the topic of GPF's and exhaust emissions, according to the DVLA V5c document my new 718 CGTS PDK is rated at 194 gms/km. This is a substantial increase from my previous 718 CS PDK which had a CO2 rating of only 167 gms/km. Despite having the same engine displacement and, on paper at least, only a modest power and torque increase, the new 718 GTS PDK shows the CO2 emissions rating when tested according to the 2018 WLTP standards.
