3 - Front Grills fitted. (Work in Progress)
Last weekend I tackled the job of fitting the Zunsport front radiator grills. The grill set for the 718 Cayman GTS involves 5 component parts.
2 - grills for the outer large apertures.
2 - letterbox grills for the lower outer apertures.
1 - central radiator grill.
I tackled the fitting of the larger central grill first as this radiator had sustained most of the stone impacts. Following the clear instructions and watching accompanying video clip, the fitting was easy. It took no more than 5 minutes. Likewise the lower outer letterbox grills were easy to fit. It is easier to fit these small grills before the larger outer grills, as enables access from above to locate the retaining clip.
When it came to fitting the larger outer grills I had to admit defeat. I found this to be a very tricky operation as it required a high degree of delicate yet forceful manipulation of the grill, combined with a level of finger dexterity which at the time I just could not succeed in doing. The combination of the dexterity impairment of my right hand fingers and my other hand becoming fatigued from fitting the previous 3 grills, I was forced to abandon the job for the time being. I shall return to have another go at fitting the outer grills at another time soon. The upside is, I can clean out the pine needles very easily from the outer radiator intakes at the present.
A couple of photos follow for your interest.
Brian
Brian
