George Elliott
Your comments are spot on. I'd add that the heat energy is a big factor, turbo's need to be hot, hence the ceramic coatings to keep the heat in (as opposed to jacketing with a coolant to remove heat) or lagging to keep heat in. If the air was cold it would not propel the turbine to the same extent and the boost would be negligible as a result. There is something like 30 horsepower in the spindle of a 944t turbocharger - power which is salvaged from the exhaust gas energy and is capable of compressing the cold side air to 2, 3 or maybe 4 bar. Wonderful bit of kit IMO [
] Another route is a supercharger which consumes significant power doing the same job, and mostly they are thirsty as a result. Those rear mounted units may have an anti lag injector close by to spin them up - certainly they have missed a lot of energy at that point in the exhaust system. George 944t
