My 944 1uz-fe V8 swap
- Thread starter Eldavo
edh
Best place to vent would be a duct behind the rad, into the low pressure area at front of bonnet (base of screen is a high pressure area) - Have seen this on some cars including Steve B's 924 turbo.ORIGINAL: JagdHamster Looking at this pressure diagram closely and with a knowledge of bernoulli's laws by profession, I note that point 1 is under the car, just in front of the front tyre. It then graphs forwards to the bumper and only when it reaches point 10 does it move left to right over the car as expected.So the low-pressure is actually above, in front of and on top of the front bumper (the airflow speeds up here the most, clearly, to travel over the car) However, if the air was able to flow through the car then this pressure drop would be much reduced. So the guys ares right; at the moment, the low pressure will drastically reduce cooling. However, if you make a pathway through the radiator and back out into the airflow (say at the windscreen, or even under the car like SMICs do), I think the pressure drop through the vents will be a lot less (maybe even a little positive pressure). That's the vital bit; making an exit for the airflow to rejoin.![]()
JagdHamster
edh
Don't forget the scale is upside down..... Point 20 is approx + 0.3ORIGINAL: JagdHamster Hi Edh, Look at the graph again; the back of the bonnet is point 20 and is a negative-pressure area. Venting forward would be tricky and build up pressure against the flow. I'd go for under the car or out the back of the bonnet, myself. Russ
you have to use the direct link betweenORIGINAL: xschop That's correct, I just remembered on the NA nose, I removed that plastic horizontal flat piece as well as removing the hood cushion on the firewal lip. Huge cooling increase....![]()
JagdHamster
