Steve Brookes
Moderator
ORIGINAL: appletonn
Any update Steve?
As you probably know now Nick, there's a good week or so of work left yet which means it won't be at Oulton tomorrow or Wales next weekend.
The good news is that all the new parts have arrived and re-assembly has started.
All the barrels and pistons have been cleaned up and are within wear tolerance:
New little end bearings fitted:
Cylinder heads and valves de-coked, valves re-seated and new guides fitted:
Crank polished (sorry for poor lighting):
New valve cover studs fitted where needed and inserts put in and re-tapped for the engine cover bolts (many had been damaged in the past):
Lots of new parts and seals:
The re-assembly begins:
The car, under cover in the corner, patiently waiting for its engine to be returned:
