The BMC air filter after 8k miles showing the dirty working area within the airbox.
Brian
Brian
BJ Innes said:This weekend I set about the scary job of prising off the multitude of plastic trim pieces to gain access to the engine compartment. The purpose was to replace the BMC cotton air filter element I had installed at the beginning of the year........After 8000 miles the airbox was remarkably free of debris.
Brian
Motorhead said:Andrew,
If you look at your service schedule I think you’ll find that air filter replacement is meant to be carried out every 6-years/60,000 miles...!
Jeff
BJ Innes said:Not to mention the risk of breakages or damage to the plastic trim if the technician is having a bad day!
AndrewT said:Motorhead said:Andrew,
Jeff
True Jeff, but the cotton filter Brian removed looked a bit dirty to me and I wondered whether he would have been happy to leave it there, uninspected and not cleaned, for 6-years/60,000 miles, bearing in mind the difficulty in accessing it on the 718 Cayman.
Andrew.
Wheel alignment is fine. I am wondering if this is because my driveway is concrete which was tamped rather than a float finish for grip? I shall try full lock when I am on tarmac.BJ Innes said:Brian J, and Ray,
I have absolutely no issues with front end "crabbing" on full lock, either with the original P-Zero N1's, or the current Michelin PS4S N0's. Wheel alignment geometry may be a contributor in this regard.
I have to say the P-Zero N1's are a huge improvement in ride and grip over the earlier N0 version. The main problem I had with the N1's was they seemed "stretched" on the wider 8.5J and 10.5J 20" Carrera Sport wheels as fitted to my 718CS. The rim protection rib on the sidewalls rendered useless as the rims protruded proud of the tyres. The Michelin PS4S N0 sidewalls are of a completely different profile to the P-Zero N1 with the rim protection rib overlapping the wheel rim as it is designed to do, which is to protect the rim.
This latter statement I have used in my plea to Porsche to request Michelin PS4S N0 tyres on my new GTS, as I have specced the same 8.5J and 10.5J Carrera Sport wheels. I considered it worth a try.
Brian
BJ Innes said:It will be interesting to see if my new 2019 718 CGTS comes factory fitted with the protective side intake grills.
Steve Brookes said:Looking forward to hearing about the new journey Brian. Although most of your usage will be touring again it might be worth thinking about a second set of wheels shod with Cup 2 tyres for those summer track only trips. They would make a very capable car even more capable!
