MoC2S
Hi Brian
Here's an article I wrote in 2004 .. I hope the sourcing is still available ! Won't attach as .doc so I'll paste it !
Basically an AC Hydraulics DK20 ..[
993 Workshop Part i
I’ll probably build this into a series spread over years, so bear with me !
I have coped with all manner of poor jacks on a long succession of cars, but when my last and most expensive, a Halfords ‘Yellow Peril’ 2 ton hydraulic jack, came apart with my beloved xxx way up in the air, I was compelled to get something a little more substantial. Truth be told, I had been looking for a while, and had noticed one jack make getting frequent recommendations on Rennlist – this was the AC Hydraulics range, made in Denmark. The most frequently recommended model was the DK13HLQ, a low entry 1.3 tonne high lift jack with quick lift to get the puck in place easily. Available in the US for $350 or so – others recommended included DK20 and DK20Q (you get the idea!).
So I emailed AC in Denmark, they pointed me to the UK Distributor, Weber Hydraulic. Imagine my surprise when they quoted the DK13HLQ at £380 plus shipping and VAT!! I sought clarification, asked for discount, mentioned a possible group buy .... all to no avail. Then, just to rub salt and mustard into the wounds, Rennlist people organised a group buy through the US dealer, and got their price even lower. I looked into shipping one over, the organiser was even prepared to take delivery for me and ship it, but all the quotes were $200-300, making it a non-starter. GRRRargh ! So back to Weber, got the prices on the others .... they are all 80mm entry, so no problem there. Then a chink in the armour, as patently Weber did not want to be bothered with me, and sent me off to a ‘dealer’ – the chink was they said ’they may have specials on’. Rang the two in Northampton, one quoted exactly the same as Weber, insisting it was fully discounted trade price, then got onto Partco. A little murky, but they brand jacks as ‘Taskmaster’, and the AC DK20 is there, but in a delightful shade of fire engine red, rather than AC’s demure blue. Had to order it in, but arrived next day – for £169 plus VAT. Just install and you’re set!
I had mentioned my search on a Porsche newsgroup, seeking other recommendations without success. Everybody seemed happy to cope with the Yellow Peril or £25 equivalent, and shocked that I would consider spending hundreds on a good jack. In defence of my sanity, I equate the good jack argument to the good helmet argument – buy a £60 helmet if you’ve got a £60 head ! Anyway, I’m rambling – here’s where the money goes ....
>>>> image ....... 009
Note the strength of construction, the wide base for support, proper handle with twist control of lowering, the wide front wheels with raised O-rings to make it quiet and easy to manoeuvre in the garage, the length of the beam for a good lift (this isn’t the high lift version !). BTW, I added the rubber pad – it goes snugly under a 993 at RS height with that on.
>>>> image 010
Yellow Peril – the cheap circlips pop off, if you don’t notice things can fall apart !
>>>> image 011
‘YP’ pygmy caster – note sparse supply of balls! Won’t turn under load .....
>>>> image 012
That’s what I call a ‘real man’s’ caster !
>>>> image 013
Toe to toe – low entry is excellent !
>>>> image 001
AC Jackstands are also well recommended but haven’t found a UK source yet – so after breaking a Draper one I got these 3 tonne ones from Machine Mart for £20 or so. The ratchet feature is nice, and they are strong and stable.
In summary, I am very pleased with my purchase(s). The car goes up quickly and safely, and as you can see I can jack high enough at the rear point to get stands under the front point, and ramps under the rear wheels for safety in this instance. That’s it for part one – cheers, Maurice.
993 Workshop Part i
>>>> image ....... 009
>>>> image 010
>>>> image 011
>>>> image 012
>>>> image 013
>>>> image 001
