Update, not too much has been going on with the car since winter and more lockdowns kicked in..
I did have an issue where I broke down on a busy bypass, this was down to a voltage regulator with sticky brushes.
So I replaced the dodgy VR with a new BERU one, a really simple job to do.
Pull this forwards
Remove a cover, 2 screws to remove old one and put new one in, simple.
As the car is getting on, some of the bushes have been changed to an unknown brand of Polyurathane and OEM by a previous owner, I wanted to just refresh EVERYTHING. So I went for the full Powerflex kit, wishbones, gearbox and ARB bushes. I chose the new Heritage range of bushes, these are not as firm as the usual yellow, purple and black bushes that Powerflex are known for. These are grey, which indicate that they are the Heritage range and with that, not hard but OEM in feel, if ever so slightly firmer but won't degrade like rubber bushes, so will outlast them and keep motoring for many more years to come without lose in performance.
Changing bushes is the worst job for me, it is just one of those pains, I will be investing in a press to make it much easier and then it may not be a job I put off in future. The results are always the most satisfying however, that's the drive I need to remind myself so that I get on and get it all fitted.
I got myself some later spec 4 pot rear calipers to upgrade my baby 2 pots, I will be stripping and rebuilding, new piston and dust seals anyway. New finish, decal and stainless nipples.
I got to work on fitting the gearbox mount bushes.
Just fitting the gearbox bushes alone has made a noticeable difference, the car generally feels more solid and the pickup when initially setting off is like a sport mode button has been enabled, it is a night and day difference and for the effort and cost, hugely worthwhile doing! I fitted the insert kit which fills the voids around the existing bushing, I went for this option rather than full bush replacement for ease, I don't regret it as the improvement is superb. I went for the void filler bushes on another car of mine which had good results (mx5 differential mounts), no disappointment here with the 964!
Finally, I was getting a bit fed up with my car cover leaving light marks, dust getting under it and coming to the car during these cold months to find a hazey finish on the paint and windows and even my gauges, where condensation had clearly got to it.
I bought a car bubble from ebay (www.carbubble.uk) £385 or so and now, the car will stay immaculate and save me the annoynce of marking the car and condensation damage! My Golf sits in a Carcoon in a damp garage and it has remained perfect so I know the benefits of these chambers. Well worth a purchase!
Next are these 2 big boxes
Pull this forwards
