New Owner
- Thread starter lthom
dave364634
cheers for the info gents.
pauljmcnulty
ORIGINAL: pauljmcnulty
erm, what's that tyre? [8|]
Paul I think you will find that its a Dark Horse II a little better then the Hero I had on a Golf.
ORIGINAL: dave364634
15 - my steering wheel vibrates above 60mph, is this likly to be wheel balanceing, or a steering colume bush?
ta.![]()
Mine did that recently - inside edge of both front tyres shot to bits ie no rubber never mind tread!!!! I had a lot of play in one damper body and discovered diffirent struts on each side one large diameter spring one small, (mines an S2) ÂŁ1200 later its all as new
Inserts for 2.5 and 2.7 cars can be had for ÂŁ120 each The rest (turbo or S2) seem to require full struts cheapest I could find (Sachs) ÂŁ259 + vat each
Spriings from Porsche ÂŁ139 + vat
lookingfora944
I too am a brand new S2 owner.
Picked mine up last Thursday
I had to laugh at your post regarding the sunroof. Going home on the motorway, mine was flapping all over the place so much so that I had to open it. I thought he had sold me a dud!
But actually. The retracting things that hold the sunroof down should not be retracted right back as this is for complete removal. Press the open button very slightly and they will come out and hold it down!
There are various manuals that show how to remove the instrument panel. You need to first remove the steering wheel. I aim to do this at the weekend as my dash does not light up very well.
Unfortunately there is conflicting information of the socket size I need to remove the retaining nut on my S2. 28 or 27mm seems to be the general size!
On the '84 car you should be able to reach up under the dash and push the l/h pod out, and change the bulb, but sometimes the wires get tangled.
Its a 24mm nut on the early steering wheel (the horn pad just pulls off) and there are 2 screws holding the dash in - top of the 2 side pods, but you will probably have to take the ignition lock covers too.
Good luck with your cars
alwigley
As you have already found out, we have some very useful people on the forum, so don't be afraid to ask, but do expect the odd sarcastic comment [
Duffman502
http://s658.photobucket.com/albums/uu301/duffman502/?action=view¤t=79394852.jpg
http://s658.photobucket.com/albums/uu301/duffman502/?action=view¤t=8dc2a6cf.jpg
Duffman502
And im only 22 so i dont want to be grey any time soon.
Its definately going to make me poor though.
944 man
ORIGINAL: Duffman502
944 man
My initial thoughts are that the interior looks clean, but its been re-trimmed; that it probably has aftermerket wheels (although they could be genuine wheels using large spacers) and that the sill covers make me apprehensive about the state of its sills.
Also: theyre Neils initials.
Simon
Duffman502
Duffman502
And i think the wheels are genuine with spacers what stamps do porsche put on there wheels?
944 man
Simon
944 man
Cheers for that do you have to embed it or something i normally copy an img code from photo bucket?
Click 'quote' on my post and youll see how the syntax differs. You need not [img] and Ive deleted part of the link.
If the wheels are genuine theyll have a Porsche part number stamped inside and the width in inches and the offset in mm alongside the valve.
Simon
Duffman502
