Oil change
- Thread starter Big Les
sawood12
berg944
Raise the headlights. This moves the mechanism out of the way and makes the oil filter much easier to get to.
If you do this disconnect the battery and raise headlamp manually.
Better to have disconnected battery than disconnected fingers [
Mike[:'(]
sawood12
ORIGINAL: 924nutter
Being new to 944 ignition systems, does the dme relay control the spak via the ecu? If it does then what about if he removes the dme relay and the spark plugs? He can then whizz the engine over with virtually no load and build up pressure.[8|]
The DME relay controls the fuel pump and has nothing to do with the ignition side of the system, althogh the DME computer in the ECU does control the ignition. I think the DME relay is commanded by the DME computer as if there is a problem with one of the engine management sensors (crank sensor for example) the DME will not swith the DME relay and therefore the fuel pump will not operate and the engine wont start - although it will turn but you'll have no fuel and spark as the DME computer also will not command a spark.
I don't recall the headlight mechanism being in the way of the oil filter. I only had a problem initially unscrewing the oil filter as my filter removal tool was too bulky and I couldn't get enough of my hand around the filter to unscrew it. Once I managed to get the filter loosened I could unscrew it with my fingers.
True. I would ask why the mechanism should start moving for no good reason, but given the ease with which you can pull the fuse, why ask the questions and why not just do it? I'm quite attached to my fingers ...ORIGINAL: Fen
You just need to pull the right fuse, but I agree; the headlight motor doesn't take prisoners and you wouldn't want to have a finger in the wrong place if it decided to move.
.... whereupon your manual dexterity takes a turn for the worse, and you get an interesting collection of slightly crunchy sausages for breakfast.ORIGINAL: Fen
It shouldn't start moving, but it might if someone touched the light switch or if for any reason the mechanism was moved slightly as then the motor takes over and completes the move.
Doesn't bear thinking about, does it? I'm taking the fuse out in future. (Although this never occurred to me before.)
Incidentally, on the 928, the headlight mechanism is prone to wearing, and the connection bar (runs along the width of the car, connecting the headlights) has a habit of shedding it's circlips. Should the very end circlip go walkies, the mechanism can slip down the bar, meaning that next time you operate the lights it pushes one of the levers through the air-con condenser ... which cost about £900 from OPC, or so I'm told ...
berg944
Knocking the manual control wheel with the rubber boot off was that reason[
Made me jump, good job I wasn't stretching across the mechanism[
Mike[:'(]
AndrewS
You still need to change that engine oil. For cars that burn a lot of oil, there are many contaminants that collect in the filter and languish at the bottom of the sump. Hence, very important to change the oil frequently (6,000 mile or sooner if the car is used hard or in extreme conditions). Essential to use a good quality oil that is the right viscosity for your engine (considering it's mileage and wear).
My advice would be to continue to change the oil at least every 6,000 miles. I understand your logic if you are adding a litre every 1200 miles, but the contaminants will still accumulate (they don't burn off or leak like the oil may do). A full oil change (with filter) is 7 litres for the 944 Turbo.
Regards,
Andrew
George Elliott
T'was just a thought[8|], I guess I knew all along.
Chris, the cooler explains why I did not need as much oil as Andrew mentions. - thanks for the reminder.
Filter removal is a messy operation too.
George
944T
