Got the car up on jacks and, with a family friend, we got the front strut inserts changed and new spax lowering springs fitted. The Koni struts were called K2 and had a large threaded adjuster collar with a part number stamped on it which started 951. I thought these were aftermarket struts and so the inserts should have fitted without bother but not so. The struts had a non-cartridge damper so I had to drill the base of the strut to accept the new damper holding screw although it was not necessary to cut down the strut body. Were Koni's ever standard fit on S2's? Perhaps from the Turbo SE??
Anyway, after eventually getting both sides rebuilt and back on the car, it was time to do the easy bit and fit the rear dampers. Only to be completely stumped by siezed solid bottom bolts! Hmmph!
Also noticed a bad case of plate lift on the rear calipers. Can the plates be eased back with the calipers on the car?
