PA1000 Remote problems
- Thread starter Stig Republic
I have the left hand fob type. When I phoned H&P (because my red master fob did not appear to be working) the first thing they did was say "are you sure it's a PA1000? do this test" (they asked me to count the number of flashes when I pressed the fob buttons in a specific way). My answer confirmed to them that I had a PA 1000. But there is certainly more than one vintage of PA1000 because H&P told me to try a slightly different procedure with the red master fob (different from the instructions that were in the car's wallet) - when they worked they said "that's the newer version of the PA1000". But my car is a year older than yours so perhaps the box looked different.ORIGINAL: dommorton No I double checked this with H&P and it's the older larger fobs that have a 12v batt. The later smaller ones have the 9v. Mark does your car have a PA1000 installed? seems odd you have completely different boxes etc to mine? Here's the two types of fob:![]()
Mine is the fob on the right so that clears up my battery question. Thanks for that. Is the left hand fob a later replacement or was it supplied as original in some cases. Reason I ask is that my car is a '98 registration and as such I would have thought that I had the latest system available at that time. I know that the alarms were an after market fit. Did hamilton and Palmer fit alarms to all the cars, or was the system supplied to the dealer who then did the fitting? This might account for boxes on different sides although if H&P were supplying you would expect them to include instructions as well. There is also a PA2000 I believe but I do not know what the difference are if any. Although I think the PA2000 had a total closure system included, i.e.windows and perhaps sunroof. MichaelORIGINAL: dommorton No I double checked this with H&P and it's the older larger fobs that have a 12v batt. The later smaller ones have the 9v. Mark does your car have a PA1000 installed? seems odd you have completely different boxes etc to mine? Here's the two types of fob:![]()
Yes it is odd - especially as my car was supplied originally by AFN (the dealer most closely associated with the importer) From your picture: The box on the left is in exactly in same place on my car and I have just looked up its part number from your picture: "Control unit, alarm system, central locking system" (so perhaps this is the disused non-UK alarm, or perhaps it is still used for thecentral locking) The middle box I don't have (except that I have seen something the same behind the left side of the passenger footwell plastic shell) The right hand ribbed box looks exactly same as the box I guessed was the PA1000 under my passenger seatORIGINAL: dommorton Strange yours is on the passenger side Mark. Most threads I've read and indeed H&P confirmed the location is usually under the drivers seat. I guess being a retro fit UK only system there's no guarantees they'll all be the same. Here's mine. The middle box is the one with the flashing light. I presume this is the central locking controller.![]()
