Part Weights
- Thread starter Neil Haughey
Tam Lin
ORIGINAL: 944 man
The next demon tweak will need to be.....
Carbon brake disks anyone [
My 924S with the 8V motor still in, but with no rear seats, driver's Recaro SPG shell seat, no headlining, sunroof replaced by f/g panel, f/g bonnet and polycarbon hatch, interior stripped and with (then) a lightweight battery weighed in at 1180 kg. These things are really not leightweights.
Peter Empson
I've given up trying to estimate the weight of my car, but I'll be taking it to a weighbridge as soon as its back on the road (preferably with the 944S in tow to do a comparison).
944 man
Tam Lin
944 man
Simon
Neil Haughey
ORIGINAL: 944 man
1100 kilogrammes is damned good going if you dont dip the shell and remove the wiring loom.....
I need to get to the bottom of exactly the weight difference from a dipped shell, an option I have at the moment is to rebuild my car into an EMC motorsport shell (brother has offered to do transfer for free).
Kevin gave me a figure but ISTR we may have been talking at cross purposes because the difference seemed incredible.
I don't think there is as much wiring in the car as many ppl think, I don't know maybe because I have been under the dash so many times now it really doesn't look much. I already of course have a lot of redundant wiring which I would do well to strip out prior to doing a re-shell. I estimate that about 1/2 the loom can be done away with and there are a few connectors under the dash for things the car never had.
No doubt about it though when you get to see what Kevin does to a shell it puts things into perspective, its like building a new car and is definitely something I would like to do. The ultimate modification really.
Neil Haughey
Neil Haughey
First up this a carpet set laid out
and..
Apart from thin vinyl this is all you have in the roof as trim (sunroof excepted)
The 2 pieces at the bottom are a sort of rubbery padding, the top bit in that picture is the cover for the sunroof elements and the middle part is a metal backed piece that sits at the top of the windscreen. With that lot removed but the roof back in this is what your roof looks like
and..
Note the now visible drain tubes. I had to put some bits back in order to retain the sunroof for now, in the new shell the panel will be bonded in.
Now for some scary pictures of the inside of my car, from the boot..
ignore the footplate and foot rest, those are going back in place Sunday afternoon.
Passenger footwell, note the rock hard sound deadening pads still on the car and the 2 painted colours black and red..
Drivers side, peeled back some sound deadening in front of throttle peddle and there is a little rust there
and lastly rear seat area
Hilux
Total is roughly 22 Kg as there are a couple of little bits I couldn't get out easily so have left in for now. Note that this does not include the rock hard sound deadening pads that cover the trans tunnel and floor, and are body coloured. They seem to be a nightmare to get off so I have left them for now.
If its the thick hard/brittle stuff then a heat gun, scraper and finally thinners will remove it. 20% of the effort is with the heat gun but soften it dont melt it and it`ll peel off taking most with it then use industrial thinners (not cellulose thinners) to remove the residue (the other 80% of the work). It took me just under two days to do the whole of the inside.
I have just completed this on my Mk 1 Golf project and the MOT tester on Friday had all of the inspectors under the car muttering and murmuring, finally they surfaced and one came over scratching his head and asked " We cant figure it out. Underneath the old floor is solid so why did you weld in a new floorpan over the old one [
I painted it satin black and it does look factory [8D]
Neil Haughey
Dave I will be driving it this year and if I go through with racing it next year the headlights will come out, some extra fibreglass, fire extinguisher, battery cutoff, battery box etc. to complete it as a race car. For now I want to keep it road legal, basically very similar to Lali's 968 even down to colour (fallen for Maritime Blue). Given how many new and refurbed bits I have done over the past few years with a newly built up freshly painted shell it will be almost like a new car.
The car looks almost normal again now because I have put the front carpet, centre console and drivers seat back in. Thank God everything still works because I need to get an MOT [
944 man
Simon
Hilux
it will be of to EMC in exchange for the motorsport shell I am buying, they will just acid dip it and start over for the next guy. Long road ahead still to go along.
So what do they do to it then Neil?
I assume acid dipping is to remove all paint sealer etc but keep the paint and sealer and then seam welding, bracing and a roll cage could be done by many people. Cant you get yours done without a replacement? In that way you keep the chassis plate and the stamped chassis. However if its purely for track and certificated then no problem I suppose.
When its done make sure they weld in provision (mounts) for a second seat so can I have first dibs on a passenger ride [8D][8D]
Definitely keep us posted and keep the piccies coming [
Neil Haughey
The shell will have 2x sets of harness mounts/eyes in the correct locations, part of the package.
sawood12
Neil Haughey
Once the sound deadening pads are pulled out from behind the dash there really isn't anything left apart from cabling, levers and heater gubbins. I was surprised how cleanly and easily that part of the cars sound deadening comes out. In fact I would recommend for easy weight saving to pull that stuff and the 2 pads in the front footwells. The same stuff on the trans tunnel was a bit of a nightmare because most of it had gone brittle and didn't come of the panels easily. Same story for the rear floor carpet that goes over the tunnel. In my car it was stuck down very very hard, took me about 2 hrs to peel out. The stuff in the rear of the car comes out easilly as well but as the pictures show you are left with a lot of remnants around the rear seats.
Peter Empson
