ORIGINAL: John Sims Coming a little late to this but with all the guys on a Lux except you do get molested on dual carriageways by hot hatches. Your only recourse is to move over. If this isn't an issue to you then job's a good'n. The plus side is on the wiggly bits they are sublime. Undoubtedly the later the car the more it will have evolved incorporating many improvements along the way (better suspension, brakes, bearings, ergonomics, balance, less drag even ABS if you can find one with it fitted as an option). Porsche did some very Porsche things with the engines and '88 2.5s were detuned for a year so an 87 model year Lux could well be the best. 2.7's had almost no difference in power over pre 88 2.5's. S - The added complexity of an S2 but without the advantages. Less desirable than an 87 Lux. S2 - Pretty much a less Porsche looking 968 for 1/3rd of the money - and 968's are almost legendary now. Not wishing to disagree with comments above - rust is becoming an issue and is very expensive to address properly. Take out the door vents and shine a torch into the cavity. If it is starting to go brown it isn't going to heal its self.
