PCCB on turbo and s with PVT
- Thread starter grover
Clive how do we actually use these wear indicators? Is it a case of when you cant see them the disc has got too thin and therefore needs replacing? If you have to measure the disc thickness then the wear indicators dont seem to helpI am informed the circles you describe are wear indicators
ORIGINAL: bobfair
Bob,
That's basically correct, but you also have to check the roughness of the disc. My OPC reports it has only ever replaced one set and this was due to extreme track day use on the Level 1 brakes.
David,
From the look of that rotor all appears fine. I think you need a second opinion! [8|]
Regards,
Clive.
grover
I asked the dealer to check the pads a few weeks ago when they changed the tyres offering to have them changed anyway before by euro trip but was told they are fine.
A debate with Germany will now take place about early wear and replacement.
David
