Sounds similar to my issue, where rest of functionality works but not DAB /FM, taking car back to my main Porsche agent in Guildford who fitted it for the third time to resolve!Tried the CAN - AMP switch over via the Volume advanced menu. No joy. Actually switching to AMP causes AM signal and the illumination on the buttons on the head unit to cut off.
I also have what seems to be be a weird issue. When the car is stationery everything is fine but when in motion DAB / FM / AM all seem to struggle keeping a consistent signal and the output sound fades in and out.
It doesn’t seem to be related with the location / driving path. Rest of the functionality of the pccm plus unit seems to be operational as expected. Recently acquired 996 2004 with BOSE (CD Changer and AMP in front trunk)
Any suggestions/checks ? Read a thread about the wrong connections and loop back in the antenna piece etc.
Wanted to see if anyone else has experienced a similar issue before I start dismantling things…
PCCM Plus
- Thread starter michaelcole
I am keen to upgrade to a PCCM+ for my 2003 996 Turbo. However I have a customer ivory interior/dashboard, so my question is can it be supplied with a unit surround in any other colour than black?
Thanks for any advice.
I think they only come in black. I suppose you could get a paint shop to colour match and paint it the same colour.I am keen to upgrade to a PCCM+ for my 2003 996 Turbo. However I have a customer ivory interior/dashboard, so my question is can it be supplied with a unit surround in any other colour than black?
Hi, pls could you share more about this? I have the same car and would prefer single din version… thanks in advanceI’ve had the PCCM single DIN unit fitted, looks more in keeping with my 996 C4 that is 25yrs old, everything works as it should and a great upgrade
I had the separate box for the usb connectors installed just under the dash as per pictures above. I could never understand why it’s recommended to have the box installed in the cubby….. as this takes up valuable space and you have to drill a hole in the back of the cubby, so if ever reversed you will have a hole. This position I have chosen doesn’t hinder leg room at all.
Ever seen what happens to loose content inside a car in the event of an accident?I had the separate box for the usb connectors installed just under the dash as per pictures above. I could never understand why it’s recommended to have the box installed in the cubby….. as this takes up valuable space and you have to drill a hole in the back of the cubby, so if ever reversed you will have a hole. This position I have chosen doesn’t hinder leg room at all.
You joking, so installing the PCCM in the cubby will stop thatEver seen what happens to loose content inside a car in the event of an accident?
![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f602.png)
I didn't say that - read and understand what I did writeYou joking, so installing the PCCM in the cubby will stop that![]()
What was your point in context to my original post?I didn't say that - read and understand what I did write
Phones or other devices in the cubby hole are not secure.
No need to touch them once connected to PCCM- so put them in the glovebox out of harms way.
Just my view .
Just my view .
Great idea except in 1999 996 there is no glove box…..Phones or other devices in the cubby hole are not secure.
Just my view .
Thank you for sharing the picture. Who did you use for the installation please?I had the separate box for the usb connectors installed just under the dash as per pictures above. I could never understand why it’s recommended to have the box installed in the cubby….. as this takes up valuable space and you have to drill a hole in the back of the cubby, so if ever reversed you will have a hole. This position I have chosen doesn’t hinder leg room at all.
An audio specialist in SwindonThank you for sharing the picture. Who did you use for the installation please?
How did your situation turn out in the end? I hope all is ok now.I've just taken the plunge and got my local Porsche main agent in Guildford to fix the PCCM+ in my 20 year old Boxster, collected at end of week in pouring rain. Now had a chance to read the manual and with a sunny day, thought I'd work out how it works. Not having much luck so far. The Sat Nav works but I can't get any music, followed the instructions under Tuner both for DAB+ and FM to see station list but just have a blank screen see photos. It's as if the system doesn't have an aerial connected, but it must be something more than that. Keen to use before taking it back when Dealership reopens. Any advice please?
View attachment 1014 View attachment 1015Tu
All working now, but surprised it took 4 visits to dealership, leaving car to resolve.How did your situation turn out in the end? I hope all is ok now.
I am glad it’s fixed. I don’t find the DAB that consistent but perhaps where I live. Can’t seem to retune it or perhaps it does that automatically. The CarPlay part is superb. I use Digital Radio Apps which are great.
Sorry just seen this still hit and miss, mostly missI have recently had a PCCM+ fitted by my local main agent in Guildford. All works fine apart from radio, can't get any stations on DAB or FM. You indicated you had issues, what were there and how resolved?
Do you know what they did to resolve the problem?All working now, but surprised it took 4 visits to dealership, leaving car to resolve.
