Dan944t
Not sure why Pete , but your car situation doesn't leave my mind and feels like it's bugging me as if it's my own.... and I'm someone whos never even got time to have lunch at work!
Heres what hat gut feeling is... I think and hope it is the tyres? But ... if it's not then my thoughts are bearings, ie wheels (rear ? ) Or torque tube bearings?
i hope not the torque tube.
something tells me it's something that is in motion from what your saying as under heavy load it's better or goes away would suggest bearings of some type. I've had a bad rumble in my non asperated 944 20 years ago that ended up being the rear wheel bearing which I changed both with sway bars off for them to go on the press. That particular load rumble I remember was awful but was noticibly from the rear of the cabin.
the ideal way would be to test the torque tube to put it in drive on a ramp and determin the rumble is coming from the tube but the thought if this I wouldn't advise for safety reasons! It's a shame there no easy way to stop the torque tube from spinning as your driving.
Just had a idea not sure if you could get it through but you would see in the car before you try?
right, maybe to determin the torque tube bearing you could take off both gear gators so you just have the mental part of the gear leaver coming up. Take all the sound deadening foam from around the hole that the gear leaver comes up into the cabin so that you have a clear view of the torque tube.
Now see if you can get a long thin flat head screwdriver or bar, in there touching the torque tube, and select a gear that gives the best clearence to do so. And if this is possible get someone to go for a drive with you on motorway in fith gear maybe so linkige is out the way, and get them to put the screwdriver on the torque tube when it's rumbling and put the handle to the ear and if it's the torque tube bearings then you shoukd hear this through the tube and into the screw driver!?
atb
daniel ??
atb
daniel ??
