Piston & Rod upgrade or not?
- Thread starter slickv8
PSH
regards
Pete
924Srr27l
u63af said:the air goes through the intercooler before going into the engine anyway so wont make much difference on a turbo car
Yes, the Intercooler decreases the air temperature, but if it starts higher than it could be the end result will be
a higher air temperature going into the engine. More Boost also means more Heat.
R
I agree, Roger makes "some" valid points but then again if I gave my opinion on every thread in the forum ad nauseum then I might make sense every once in a while*.
*It might also help if I was ever serious and hadn't been smashing the Xmas drinks.
Dan944t
I cant say that I noticed a huge improvement at the time but what I can say for a fact is: when it was very nippy outside and I went for a blast and turned the fan on, it felt as though I had been given another 30bhp and at every freezing opportunity as long as it wasn't icy, I would throw away £40 that night just driving about on my own enjoying the extra power till my Petrie light Glowed orange! Then off back home I went
924Srr27l
Dan944t said:I know it's a known fact that the colder you can get the induction air into the engine the faster it will go! So when I was younger (17) I had my first car which was my non turbo 2.5 lux 163bhp and in hearing someone boasting that they had rigged up there focus air con pipe to blow on the air cone, and it went so much faster! , I then began to invent new ideas for my lux as unlike my turbo that I now have also it didn't have airCon...so I fitted a super large stainless air filter cone and made a large chrome tube which sucked the air from the arch and I installed a mesh to collect any debree and also installed a fan which I could switch on and off from the cockpit, which was from a computer drive so that it didn't interfere with my radio? Anyhow this fan was set to suck in from outside air and propell the air down the pipe into my air filter.
I cant say that I noticed a huge improvement at the time but what I can say for a fact is: when it was very nippy outside and I went for a blast and turned the fan on, it felt as though I had been given another 30bhp and at every freezing opportunity as long as it wasn't icy, I would throw away £40 that night just driving about on my own enjoying the extra power till my Petrie light Glowed orange! Then off back home I went![]()
Good Contribution Dan from your "Cold Ambient Air" experience, as I'm sure many of us have experienced?
As opposed to some members who do nothing but bitch & post negative, personal insults.[8|]
It's a fairly common practice on Turbo car tuning to keep the temperatures down and if possible fit bigger intercoolers, and move their location
to a cooler area (if possible) all done to make the air supply to the engine temperature as low as possible.
Here's some info on Air Intake and Boxes,
http://www.formula1-dictionary.net/airbox.html
R
slickv8
Nowhere near driving it yet, next week I'll start chopping into the bodywork to get the arches fitted. Updates as and when they happen.
This was my car with an MBC set to 18psi - overshoot to 19psi and then a quick drop off:
http://i213.photobucket.com/albums/cc264/eldavo69/Porsche%20944%20Turbo%20S/26DED23C-651B-4E3F-BC76-546D9D729092.jpg
No other mods but an Apexi AVCR with a solenoid gave me this:
http://i213.photobucket.c...-8F13-324E18AD40E1.jpg
I was quite proud of my boost curve with an ebc clicky
On the air filter discussion, I stuck with the standard panel filter for a while, I had a K&N in there for a while but I found fine dust on the wrong side of it so went back to paper, I did manage to collapse one though, it sucked in and over the airbox outlet. (bigger turbo - higher boost)
I then went to a cone behind the headlight with air ducted through the wing to it, I did also have a small piece of plastic on the leading edge of the bonnet above the filter for 2 reasons -
1) water used to run into the filter when parked outside in the rain
2) it 'may' have deflected some additional air in - I meant to do some wool /camera checks but never got around to it.
I would have liked to box the filter in fully there is a template on rennlist somewhere to help (NZ951 posted it I think).
The colder the incoming air the better and behind the IC the radiator and the a/c condenser it isn't going to be as cool as it could be.
had a quick look for the template and found this thread http://rennlist.com/forums/944-turbo-and-turbo-s-forum/774712-maf-air-intake-isolation-results.html
and the template thread
http://rennlist.com/forums/944-turbo-and-turbo-s-forum/189363-my-first-fibreglass-effort-intake-partition-now-with-upgrades-2.html
