Project 3.0 930
carreracat
Hi all, having had my 930 for over a year now I have just begun the restoration proper.
Got some of the bits off the car ready to be transported to the workshop, starting to look better already without the boxed rockers!
Had a bit of a job getting it on the flat bed as we couldn't push it up the slope of my driveway entrance (good use of a bus stop!)
Got the car to the workshop to get the engine out
Interior also being stripped out
Good use of the seats in the meantime!?
Engine still in at the workshop, not for much longer!!
Engine out and car at the bodyshop ready for the real work to begin!
Not a bad days work to kick off the project proper! :)
Hi there, looking like a good project, are restoring the car back to original ?
I'm just starting to restore my 3.0 Turbo, chassis number 930 770 0180, new 7th Jan 1977, what was the original colour of your car ?
Andrew.
hi andrew,
the car is going back to almost stock look. as the weather is rather warm here i am keeping the inter cooler so until i can afford a new intercooler arrangement thjat will fit un der a 3.0 turbo whale tail i will be fitted a 3.3 turbo tea tray to fit over my current intercooler.
the engine will not be stock either - it has motec EFi, SC cams and a HFS7200 turbo. i would like to put it back to stock one day, but the k-jet parts didn't come with the car so i will make do with what i have.
my car was first registered on 31 march 1977 in the UK but the log card states that it was manufactured in 1976, the car then went to Japan and then to Singapore in 1982. i got the a COA from porsche as follows:
the colour is going to be its original colour again though, which should look something like this:
http://pistonheads.com/sales/2107145.htm
some progress from the bodyshop:
fake rear air scoops returned to stock, drivers door rust sorted and replacement 3.3 wing repaired and fitted :)
it's great to see it taking shape, and it looks a lot better without the air scoops already!
thanks aldo, but i will be sticking with my stacked intercooler until i can afford the US$1,700 for the turbokraft one that will fit under a 3.0 tail :) (Which i can't afford yet either!!)
Santa came early!! shiny shiny me likey :)
Updates from the bodyshop:
How much filler???
Front wings off, rust in the usual places (trying really hard not to panic!):
Some rust on the wings also
Errr, starting to panic a little now!
But it's all good, one wing repaired already!!
Great to see the project getting started, and fabulous to see the original car underneath the 'added extras'. Pictures of rusty metal seem very familier from restoring my car four years ago. Can be very scary and I did question my sanity on several occassions! Will try and post some of photos of the sill replacement on mine, if only to amuse as to how the car stayed in one piece! :-/
now that the engine is apart i know it has the following:
newish JE 3.2 pistons and barrels
original 3.0 crankshaft (thankfully!)
SC cams
boat tailed crankcase
oil pump not looking too clever
one exhaust valve guide seized on valve
a lot of crap in the oil
the cams aren't in great shape - if i replace them should i stick with SC cams or is there anything else i should be considering? 964 or Ruf perhaps?
some of the cylinder head stud holes have helicoils fitted - should i trust them or spend a fortune having them removed and new threads machined?
does anyone what compression ration you get with 3.2 barrels (98mm) and the original 3.0 stroke (70.4mm)?
Great little project. The engine has already had a few mods. What d you plan to do to it mod wise? What is a boat tailed case. Do you mean boat tailed pistins?
Great pictures....
hi pete,
yes the engine already had it's fair share of mods so i'm not adding much else, just an uprated lube oil pump (a worthy investment i hope!). so it will be a short stroke 3.2 EFi motor with SC cams and a bigger turbo - should be fun!
boatailing is where the crankcase members are rounded off to improve the gasflowing in the crankcase in the underpiston space like this:
Looking good. I gasflowed my crank case the same. I believe it makes a small difference. I though boat tailing was removing some of thew tail from the pistons. Doesnt matter either way, your engine should be pretty awesome......What numbers are you hoping for?
here's my engine build: 3.5l Motec Engine
No turbo though [:(]
hi pete,
numbers wise i will be happy with anything over 300bhp which should be easily achieved - i am more keen on reliability that outright power.
some engine build pics:
new 996 turbo oil pump
refurbished rockers with new bushes
a pile of conrods (or is that a gaggle or conrods?)
new valves
coming together nicely after some serious cleaning!
and very nice video pete, i would love to a NA ITB build one day. i was orignally look ing for a an SC or a 3.2 to start my project but i just couldn't find one i was forced down the forced induction route.
That is looking very nice Mark. I love looking at the engine in bits. They are such technical engines..... Looking forward to seeing more.
replacement parts list so far:
replacement 3.0 crankshaft
JE 3.2 pistons & barrels
piston rings & circlips
964 cams
996 turbo oil pump
reconditioned rockers
cam carrier oil feed tube
fan impellor
new clutch
timing chains
idler sprocket
crankcase gasket kit
rod bushing set
main bushing set
sump plate
cyl head gasket set
cam chain sprocket
crankshaft pulley
splash valve
964 intake valves
930 sodium cooled exhaust valves
valve guides
flywheel bolts
conrod bolts
intergear shaft thrust bearing
intergear bearing
valve adjusting screws
conrod nuts
oil press switch
chain tensioner feed piipes
oil sump shaft
oil pressure tansmitter
suction hose oil tank - oil cooler
clubsport engine mounts
piston squirters
cam squiters
Motec M600 with 550cc injectors and audi individual coil packs
K72 HF turbo
may be fitted if i can find the funds down the back of the sofa:
turbokraft full bay intercooler so i can fit at original 3.0 whale tail
yet to begin:
gearbox strip down & overhaul
Your bodywork images are a salutary lesson to anyone who buys a 911 / 930 with "just a few signs of corrosion".
Keep up the good work.
