Project S2, it's a biggun!
- Thread starter bertelli_1
bertelli_1
Anyway, the 'good' cylinder head is now with Promax, who are going to arrange getting it sorted. At the very least it needs a skim but may need a bit of welding due to corrosion.
The bottom end seals are in stock at promax so I'll start assembly soon.
Northern924
Really looking forward to seeing this one back to its former glory, always sad to see another car die but its all in a good cause [
bertelli_1
bertelli_1
Now the body work. I've started the cleanup & have done some before and after shots of the worst side. My missus bought me a pressure washer, it made the work so much quicker & easier. It still needs further cleaning & a polish but the car will be sitting on the drive for a while yet so there's no point doing the job twice.
Thats what I call dirty & you haven't seen under the bonnet yet! Next on the list is to recon the 2 sets of brake calipers & sell off the spare ones which should pay for some more engine parts.
bertelli_1
Surprisingly I found another problem, I had noticed the cooler takeoff has about 3 tubes worth of sealant on it. When I removed it I found a large crack, so the original engine will be donating another part. I've probably used more parts off the 'damaged' engine than the 'good' one now!
bertelli_1
And here is a pic of the swarf next to a 13mm socket for comparison. It doesn't take a lot to ruin an engine.....
912UK
ref your paint you can mop ( trade talk ) the paint with some G6 and G10 and then clay and polish it will come up nice I am sure..
bertelli_1
bertelli_1
And lovely smooth (and out of focus) finish afterwards -
The amount of time it takes to refurbish a head cannot be underestimated, fortunately I don't charge myself labour. Once the valves & seats were done I could temporarily assemble the head in order to measure the valve spring lengths, then determine where each shim should be fitted (I had a mixture of 1.6 & 2.0mm shims). Then it was all taken apart again, cleaned again before final assembly. The finished head -
Thats another big step forwards, next up is actually getting the engine in the car.
bertelli_1
However they last over 10 years so I don't think there is anything wrong with the standard gasket - but it is good adavice to change it wherever you are if it has not yet been replaced in the last 10 years say.
Baz
p.s. if any of my postings sounds like I am immitating an Italian I aapologise - just like in the previous word - a letter a has satarteda appeaaaaaaaaaring alla over the place following some water coming on to my desk anda keyboarda - this sentence being the one I didn't go back anda edit! Quite funny really!
Diver944
ORIGINAL: bazhart
Just how old is the gasket on that keyboard Barry? [
bertelli_1
