bertelli_1
I got a few more jobs completed, adjusted the tailgate so it fits properly, started cleaning the interior - there is now no evidence that the engine ever used to be in the boot! I swapped the gear gaiter for a better one and discovered a mouse had been living in the foam sound insulation above the torque tube - the little blighter must have eaten about half of it judging by the mess! I guess thats always a risk when a car has been standing idle for so long, he did leave me some nuts though. I also removed the alarm, I had briefly mentioned it had 'issues'. After I first got the car running I left the battery connected & locked it, when the mrs got home I proudly unlocked the car & went to start it - all I got was flashing hazard lights & no start. A quick inspection showed no fuel pressure, this & the hazard lights pointed to an alarm fault, the fuse board was removed, & the fuel cut alarm wires bridged and it was all good again. To avoid any further issues I decided to completely remove the alarm which turned out to be a hamilton & palmer unit fitted in 1994 - the car was registered in 1991. The module was under the passenger seat & had got damp, the circuit board was quite corroded -
