I feel a little compelled to add my experiences modifying these cars. I don't have any experience with the Lindsey kits but their products are generally well thought of. Having said that I (yet again) agree with Fen. Firstly a number on paper that may or may not be achieved to the detriment of driveability is not really that useful. Though at this point I may add that I don't think that having large turbochargers neccessarily means that you can't enjoy the car. I don't really see the point in having a totally linear power delivery on a turbo'd car. To me that seems almost a contradiction of terms. If I wanted such a response I would get a V8 and do the conversion or just buy a different car. I want to feel a little lag followed by that intoxicating push in the back when she cuts in.
Just to give you an idea, I have a Vitesse Stage 5 turbo rated about 730hp, I have a modified head that actually produces the numbers that others claim to ( and these have been compared on a proper bench flow) but is suited more to the top end, a very big cam, full 3" exhaust, and when I was running the car in on .5 bar and 4500rpms with the timing completely out on the cam (in other words the car should have ran like an absolute DOG!!) the car was fantastic. It felt like my old engine that was about 300hp crank on 1.4 bar.
Now as Fen alluded to, I have also gone up in capacity to 3.0L and that's what I attribute the bulk of these glowing words to during the run in period. In other words for $8k (is this in GBP's ?) I would think that you could get something more solid that you could add to. In other words you could get a long block assembled and shipped from the US that would cost you less, have 3.0L capacity and be able to add to that over time. You would be starting from a bullet proof bottom end. Or you could buy the components like Darton Sleeves ( I would suggest dry ones), maybe JE pistons *, Arrow rods (UK) and have some machinist do the instal, have your head cleaned up and go from there. That would cost you much less than $8k. The other issue that has been touched on is of course you can't start running around in a higher performance car if you can't turn or stop. There is a lot to be considered when doing upgrades. Put a plan together and really do some research. This is the 'Domino theory' incarnate!!! It is very easy to get on a slippery slide. Just ask me how. [
Otherwise get a good chip, fix your brakes, upgrade your suspension, get a dual port wastegate, boost controller and have some cheaper fun. Afterall that is why we bought these cars in the first place.
*If you wind up doing the sleeved block be very careful to research the piston to cylinder wall clearance needed. While dealing in increments too small to see, there are mistakes to be made that can be a total pain...again ask me how. [
Good luck in your pursuits.
Patrick.
