Mr968
fix your brakes, upgrade your suspension
Couldn't agree more with this, not forgetting that you didn't know what bhp car you had,(sorry) it sounds like excessive mods to the engine would be a step too far for you at this stage.
First Brakes.
Upgrade your brake hoses to Goodridge, get some decent brake fluid in and some performance pads, make sure your calipers are working correctly, that will get the brakes sorted, which is the first thing you should consider and is usually the cheapest upgrade and usually you can do it yourself. You could also go for bigger calipers but then that starts to cost hundreds.
Then Suspension.
Make sure that your current suspension is as good as it can be. Preferably change to Koni Sport dampers(that doesn't mean M030). Or if contemplating going on the track go for KW.
You might consider changing the bushes to Powerflex.
Then Engine.
Before you do anything, as mentioned I'd make sure that you have an engine that is sound before you do anything. Have it rebuilt if necessary to achieve this with strengthened/new components. You are worried about costs now, imagine how upset you would be if the engine blew up.
Do the mods as listed above in that order for the most cost effective performance upgrades, and on the way do the research and talk to people like Fen and the others on here about engine mods.
(Fen, yes the option code for LSD was L220)
