ProMAX Level 4
- Thread starter h4x0r7000
ORIGINAL: Fen
I did experience it on the road - windy and wet quite often. I did 5,000 miles in it between August and May and only 2 track sessions, one of which was an evening where I started late and was black flagged for noise so finished early.
What I want is something that feels fast with no frame of reference - it's push in the back I'm after not overtaking punch or reeeling corners in quickly.
Ah but I thought it was closer to 300 for most of those miles. Rockets are probably available on ebay
Tony
http://www.cannell.co.uk/images/Dyno_Graphs/C7KOE_Boost_2.jpgORIGINAL: evil 944t
Am I missing something? I don't see the boost level?
Also, Is a 3rd gear pull normal? We/I always do 4th gear pulls. It really helps load up the motor/turbo.
Its around 21psi but creeps up to 21.5, I believe its third, not that car but on another 944t we did a 3rd and 4th gear run, graphs could be overlayed, I believe that run was 3rd, but Mark or Andrew could probably fill us in.
Tony
Which is on a standard AFM, K26/8 and standard exhaust only makes around 320BHP but lots of torque at 18psi.
I wish we had found what it would do with a MAF and ball race turbo, but unfortunately the owner decided to sell before we found out - he regretted it almost every day since
Tony
- ProMAX Motorsport - home to some of the most powerful 944 Turbo's in the UK announce the 2006 evolution Level 4 Kit! 441.9 bhp and 391.2 lbft (401.9 bhp and 334 lbft when tested at the WRC Silverstone Dyno Dynamics Facility).
- Uprated Turbocharger, Intake, Stage 3 Cylinder Head and Customised exhaust system.
- 3.0 Bar MAP Sensor with specially adapted and integrated MAP system.
- Only available to order and exclusively fitted by ProMAX Motorsport in the UK at the Milton Keynes Performance & Service Centre.
- Guaranteed 400+ bhp (NOTE: subject to your car being in suitable condition to start with) Click here to view a larger picture.
ProMAX Level 3 Performance Kit - £7999.95
I believe the exact details are a closely guarded secret,
However my guess is Lindsey turbo, head, intake manifold, hard pipes, IC, SFR 4" exhaust adapted to fit RHD, Map sensor from another german manufacturer with custom piggyback, injectors - I hope uprated fuel pump, not sure which HG probably cometic, air filter and custom intake pipe for larger turbo.
Fitting and tuning.
I would say, they could move the torque curve to the left if they got rid of the short tube intake runners. I had that on my street car for a couple weeks and a dyno pull before going back to a modded stock manifold with larger t-body.
ORIGINAL: 944Turbo
ORIGINAL: Fen
Actually that's true - about 4,994 of them in fact.
ORIGINAL: evil 944t
What does that cost in US $$ ? Is that euro $10k or $16k?
It's going to be close to $16k based on the last exchange rate I saw.
Hilux
To accelarate quickly you need a torque curve that is closer to being flat across the engine range you want to work in - decided by the gearing and max revs you are going to run the engine to.
Thats my view too.
Power is a function of torque, without torque there is no power. A flat linear (high as possible) torque `curve` is the better compromise for grunt throughout the range. For fast acceleration the engine characteristics are to place the max torque in a small area and generate max power in the higher rev band however this only really works above 5252rpm on 4 pot engines.
ORIGINAL: nick_968
8 grand on a 2.5?? Surely you would be better off just buying a brand new 3.2 engine!!
If you have the skill to do it yourself it'll always work out cheaper than getting someone else to do it, but either way you pay your money & take your choice. I think most commenting on here clearly prefer to do it step by step & learn it for themselves. I don't think this product is aimed at people like that.
It seems to me that for your 8k you're not buying a specific list of parts, fitted, you're buying the guarantee. I guess they'd fit whatever parts it took to achieve that & it's a serving suggestion, not a menu. If you want more low end torque & are prepared to spend the money I'm sure they'd do that too & charge you accordingly, just as any other similar company would.
Anyone know how much it would cost to buy a 3.2 fitted & running (regardless of specific power)? Jon?
ORIGINAL: Riverside
There are many ways to come up with 400rwhp. Displacement and proper turbo for improved low end or stock motor and ring its neck with a large turbo.
Regardless of which way you do it, it comes down to parts, labor and $$. The reason why I asked what comes with the kit is because I want to know what I'm getting for the money. I'm also curious to know if they are doing it right. By that, I mean, are they using the proper supporting parts to help the motor withstand the extra power.
A guarantee that it makes 400hp is great but I would rather a guarantee that it will make 400hp and survive. I wear rate doubles when you start boosting high.
I can find you a huge turbo that will force a ton of air through your retricted stock head/intake/t-body/stock cam etc.. and make 400rwhp. You would also have to run your engine at a rpm it was never intended to run at. Thats easy or would you rather I build you the proper motor and use a smaller turbo and run less boost and run the engine at a lower rpm?
For the record, I'm not downing the product. I'm just trying to educate myself. My questions were to find out what you get for the $$.
As far as a 3.2ltr price goes. Why stop there? You can build a 3.4lt turbo with stand alone ems and turbo for $20-25k(us). It could cost more or less it depends on 8v or 16v head/cams and exhaust and intake parts.
ps - that should put you in the 600rwhp club with low boost.
ORIGINAL: evil 944t
I think you've probably answered your own question there [
ORIGINAL: evil 944t
I'm not upping it either, as far as I'm concerned it's more money than I'd be prepared to spend on my car regardless of the amount of benefit it would give, pure & simple.
If I were in a position where I wanted a car to take my breath away I would scrimp & save to buy a lambo, however I'm lazy so to feel breathless I just smoke a lot [
sawood12
Vitesse Stage 3 kit £2k & 350bhp
Promax Stage 4 kit £8k & 400bhp
Jon Mitchel 3.2 ltr special £10k+ & over 400bhp
The beauty of the Vitesse kit is not necessarily the headline power and torque figures but the drivability of the kit and the fact it is virtually a plug & play solution that works with stock intake manifold, cam and throttle body, also the ease of tuning via the piggy back system. Also it is a kit that will grow with any future mods you might install. And judging by the number of people using it in the states perfectly reliably it appears not to overstress the mechanicals of the engine. Whichever way you look at it is appears to be a decent piece of kit.
