ORIGINAL: Hilux
Unsprung weight is more critical in outboard wheels on light cars a la westy`s and F1 cars, less so when inboard like ours.
I don't know where you're coming from with the outboard vs inboard wheels bit, but I certainly agree that the proportion of sprung to unsprung weight is a factor in how much effect increasing unsprung weight has on the car's behaviour. The lighter the car the more difference increasing unsprung weight by a given amount makes.
ORIGINAL: Hilux
Why have brakes that are on their limits when you could (SHOULD) have brakes that are well within their performance parameters for the additional massive kinetic energy increase that can only be lost via heat dissipation.
To answer more fully, one of the reasons for not having the biggest available brakes is to avoid increasing unsprung weight (another is cost). It's a compromise, not win-win situation. I'm sure most here would argue that the benefit of BBs outweighs any downside, but to imply that it's a no-brainer is foolish imo.
The benefit of bigger brakes & more consistent stopping power needs to be balanced against the detrimental effect to the roadholding (keeping the tyre in contact with the road) of increasing the unsprung weight. The same problem applies to big wheels, which of course would be needed to fit over BBs.
Add big wheels & big brakes to a car without altering the springs & shocks to suit could be problematic, the suspension needs to be tuned to work with the masses at both ends of the spring/shock, not just the body. The effect is quite noticeable as Fen describes of his MX-5, I had the same issue with my old lux when I replaced the original 15" wheels, I just put the original wheels back on to solve the problem rather than changing the suspension though, it was cheaper [
It's been a reccuring theme throughout this thread, one needs to consider what effect a change will have on the rest of the car.
I hope your Flabber is feeling better [
