Quest for lightness.
- Thread starter ocallen
berg944
That's a really good figure Mike, in fact I'm really quite surprised at that!
Re-shelled with Mk1 shell about 1990 when it was a track car......probably lighter shell but don't know the figures.
Mike[:'(]
Neil Haughey
ORIGINAL: sawood12
Also it often amazes my why people with track dedicated cars still retain the dashboard and stock fan and heater system. Surely a few aftermarket gauges bolted onto the bulkhead and an aftermarket racing fan unit will save a hell of alot of weight. The amout of wiring and gubbins behind the dash must weight a good few KG's.
I guess it is pointless chasing a few KG's and alot of money on carbon fibre body panels until you've been as drastic as this. Reading on Rennlist I get the impression that there isn't as much as you'd expect to be saved with a Carbon Fibre bonnet, and less to be saved with carbon fibre wings. Spending a grand to save 20kg's out of a 1300kg car doesn't make much sense and isn't going to transform the cars performance at all. It's icing on the cake stuff.
Well that pretty much sums up the whole modding scene really, which is why I have come round to the conclusion you either have a race car/semi race car or just keep it more or less stock.
For a PCGB spec S2 it looks like one needs to get the car under 1100 Kg since the cage etc. etc. is going to add back in loads, that is a pretty big drop but looking at all the info I could find is doable. ISTR Andrew S mentioned before similar weight loss with his race cars. Dropping 200 Kg is going to make a massive difference to the on track performance with welded in cage and race suspension is going to be on a different level to what most of us are used to.
Stock dashboard will be required by the regs or it won't be which is what decides if you keep it. Heater ISTR you require to be road legal but again if the regs don't say you need it it comes out of a race car and will save a nice little amount of weight for sure.
I remember figures for fibreglass bonnet and wings that show a very big weight saving over the steel, something like 20 Kg in the bonnet and 6Kg a piece in the wings (ISTR its the underseal etc on the wings that makes em so heavy). But of course this for race spec parts that are designed to be "crashed" as 944 man puts it rather then look trick [
Stripping out excess wiring is a defo for me, in fact I have been naughty and already started it when I removed the stereo and speakers a few years back. I had a poke around thinking about normalising the car and selling it but couldn't find the speaker cables. It is amazing how much wiring there is a 944, its very messy because of that goo they put everywhere but pretty easy job IMHO if one is good with electrics. Not going to save a massive amount of weight but if anything less wiring that may or may not have power means better safety IMHO.
944 man
Neil Haughey
944man would you recommend dipping a shell over say stripping the old fashioned way? My local guy referred to it as an option that has become popular but I didn't get the impression that its a necessity.
944 man
Itll help you when you come to do all of the seam welding thats prohibited in the rules, too.....
Simon
Peter Empson
ORIGINAL: ocallen
Peter, what are the heavy bits ? I want a 1/2 roll cage but I think thats 30 kgs.
My half cage weighed 16kg on bathroom scales before the harness bar was added (I now can't recall if this was with the diagonal fitted or not), the car also has heavier wheels, brakes and the SC and associated paraphernalia add a lot. There are lots of other little things that add up to like the abr's and rear springs etc.
Neil Haughey
[ORIGINAL: 944 man
Simon
