roll bar settings
- Thread starter rs phil
paul howells
A good example was spa with my old 993 cup,1 set of cup tires i thought were ok,had done 1 qualy and 2 x1 hour races,and only 1 month old ,testing at spa was 3 seconds off with these tires,new tires ,2nd lap 3 secs gained! They do last a long time but also lose a fair amount of grip quickly,but if you are track daying , times are not important and you can wear them down to the canvas nearly.
Your tires may be fairly new but heat cycles kill the tires quicker than age.
Dunlops handle the heat better than toyos,but nearly as noisey, not as good in the wet as the toyo.
If you run the rear bar in the middle you will probably need the front on full soft.
Hope this helps
paul howells
Looked at your post again,manthey ring set up,circuit or Northern loop.
The car has a lot of camber for the loop,more so for the track i would have thought.
Also with the amount of camber on the front,you need to push very hard to get the full tire working.If you dont, to much camber also does not help understeer on intial turn in,and mid corner with fresh diff plates will also help push the front of the car.
My 74rsr racer i now have ,i had new lsd plates,i put 2 plates together on each side of the diff to reduce understeer when on the gas out of the corner,as the diff was to much.
The other problem is that you can not set up or make accurate judgement on old or heat cycled rubber.
Hacki
ORIGINAL: paul howells
I think that´s the key.
Start setting the car up on a fresh set of tyres on a dry track with enough time to work on it.
No two cars are the same, but I´ll tell you my set up:
Rear full soft
Front second hardest
Toe in 0
Standard Cup springs and dampers
I don´t have the camber on hand, but it´s almost 0 rear, and about1,5 front
That is a compromise between road use, Nordschleife, track days and clubsport on road legal tyres (Slicks = different story)
One could guess it will understeer due to the roll bars, but it doesn´t. There´s very little understeer in slow corners, it´s absolutely neutral in fast ones, well balanced.
Ever since it´s set up like that it works everywhere and tyres last way longer than before. It´s a disadvantage on a GP track, where you need loads of camber and a low low car, but that´s no problem for me. It´s a compromise, so not the quickest set up on a very smooth surface.
A few of you know my car, it slides smoothly over all four wheels out of Pouhon, just great.And like all of our cars, when you really try too hard, your back will overtake you.
After having set the car up, I had the chance to have it tested on the Nürburgring GP track by a Porsche factory driver, who knows these cars very well. He really let it go and after a few corners he said: "The car is wonderful neutral, don´t change anything on the rollbars."
That was a nice confirmation.
Before I started working on it, I slided around as helpless as seen in the video. Tyre presssure way too high, not cornerweighted, wrong rollbar set up, toe in too much, etc. So we put fresh rubber on, had a full basic geo, cornerweighted it and within 2 days the job was done. But it takes time and real experts, the basic geo and cornerweighing took about a day, second day was driving and setting the rollbars up, until it worked. Last changes were done by adjusting the right height.
(It´s not low, as said, it´s a compromise set up)
In the cool dry weather of Spa this year I started with 1,9 bar front cold and 1,8 bar rear cold (road legal tyres), which was about 2,4 bar hot all round. In hot weather about two or three tenths less cold. The car won´t drive with more than 2,4 bar hot, not at all!
(On slicks or Cups it´s probably a little less from cold tyres and should be less when hot also)
Maybe that helps, good luck
Hacki
65 mat
Isn't that how you are supposed to drive then?... looked like a typical trackday for me
