Rough idle, occasional cold start smoke, 987 .2
- Thread starter 911hillclimber
Boris the spyder
Boris the spyder
the display on the dash is checked hot after a good run, ie after a minimum of 25 mins road running.
level drive, seat belt still on (!) and wait for the computer to read the level as the oil settles, about 30 secs at most.
all the bars are 'full' in the end and I think this is the correct level.
however, the oil could be over the mark significanty. Draining some out so the test gives one bar down is easier said than done. Maybe Ican hand pump some out of the boot mounted filler kneck.
i go to the local indie a week on Monday for the a/c test, so will ask them to get 0.5 litre out.
the club is running in early August a tech session on the 987, gen 1 and 2, I'm booked in and will be looking to separate fact from fiction or myth about these 2.9 engines.
Boris the spyder
Briggy
Cheers,
Bryan
I'm assuming all is correct.
As the engine is not dry sump etc why does this engine need to be hot and running for the check?
I'm sure there is a Porsche engineering logic in there somewhere.
Good belch of oil smoke and then clear.
Drove the car 5 miles and stopped on a sloping driveway for 2 hours.
Re-started with a warm engine, same again.
I think I've now had it with this car, just wanted to vent by spleen! [>:]
Not wishing to teach you how to suck eggs, but is it definitely oil (blue) smoke? White or black smoke would indicate respectively that it's coolant or fuel related.
If you're definitely burning oil then a cylinder compression test and borescope check would be useful to identify any potential problems.
A loss of coolant would indicate a problem there and a coolant system pressure test should confirm the system's integrity.
If the engine's over-fuelling on start-up for some reason then you could get a blast of black smoke. Maybe an injector is malfunctioning?
A rough idle could be due to a faulty variable valve timing (VarioCam) unit. A full diagnostic check should indicate if there's a problem.
Jeff
Gordon Attar
Boxbrownie
Briggy
I can type up a guide if you want to change them yourself. Cost about £250 for the full set of 6 from OPC.
Cheers,
Bryan
the smoke is dark blue and smell oily, not white for sure.
the car starts cleanly 80% of the time or better, but every now and then....
when running and hot the tick over can slowly get rougher, say after a minute of idle.
I will be taking the car to the indie who has pm'd me and see what they make of it all.
I Don't know if the coil packs have been changed etc, so hope the indie can find more out.
I'm sure your Indie will do it but I think the plugs need to come out to see if one is fouling due to it oiling up. Obviously it would be best done when you're getting a rough idle condition.
The condition of the coil packs can be assessed at the same time.
Don't give up yet.!
Jeff
this is a great car, but the issues spoil the whole experience.
by contrast I ran my '73 911 with a 130k mile old 3.2 in it today, ready for Silverstone this weekend.
started well, no smoke, ran great, steers like a dream and felt ready for anything.
brilliant car.
The complexity of modern vehicles really is astonishing compared with those of the 70's, especially the electronics and electro-mechanical components. Hopefully your Indie has the necessary diagnostics - and the skill to interprete the results - to throw some light on the problem, if indeed it is electronics related. After that it's just a process of elimination including, if necessary, a mechanically related source of the problem.
I hope that everything turns out well for you in the end and that you end up having a more positive experience of what is an excellent car.
Jeff
The rather occasional nature of the fault would indicate something moving outside the engine itself and there are a variety of ducts, pipes etc in the crankcase ventilation system all of which are worth investigation, listening through a tube while flexing the ducts may reveal something as any leaks will produce a suction"whistle" but it will be close to the ultrasonic level and so difficult to hear, AOS is the most likely item to pass oil but check the oil filler cap for creamy discharge, in case of other internal oil leaks although some will occur with too much short running and that won't cause oil in the chamber unless the is something such as head gasket very unlikely in this case from what I have read here.
