S2 lost power funny exhaust noise, Help
- Thread starter jamieda
PSH
Sorry to hear of your woes... the guys have given some good input...i would add that don't start stripping the engine down before checking everything else first, you say it's not firing on number 2, so check all avenues relating to this first...check for spark, check for fuel, if you have both then compression would be next. I'm surprised that you say it's not lumpy, it certainly will be if only firing on 3 cylinders. You posted the video of the exhaust note which does sound as if only firing on 3...it may help to post a video of the engine as more can be told from the sounds coming from there. Considering that this happened after a day on the track then my suspicion would be the head gasket, certainly if it was a turbo.
If as suggested that you have dropped a valve or something I would expect noise from the engine...all I can hear is it firing on 3, no metallic sounds but then as stated we only have the exhaust video to go by. again if it was a turbo i would also suspect a burnt out valve but doubt this on an S2 model unless something is seriously wrong with the mixture. Regarding the oil leak, if I'm reading the picture correctly it looks like the back of the engine, again considering you were on a track before hand and also that you mentioned revs but now power to the wheels this would point to the rear crank seal leaking and contaminating the clutch, it may be that you have more than just the engine playing up. It's interesting that you say number 2?...this is not normally the cylinder where the head gasket fails, number 4 is the most common cylinder to fail although i will again state that i'm more familiar with the turbo model. Number 2 is however prone to the wrist pin failing due to oil starvation, especially after track use, there's a design flaw in the oil passageways that means that when driven and cornered hard on a track less oil gets to number 2 piston wrist pin and it will eventually fail, it certainly wears quicker. Your symptoms are not this though, not unless you have a rod sticking threw the side of the engine block..
To summarize check out as much as possible, if you have fuel and spark on all cylinders then you may have to start taking things apart, I would let a specialist look at it first though as it's difficult to find what's wrong if not obvious once it's all apart...good luck...
Pete
robwright
PSH
Pete
PSH
Pete
Fred Hindle
Cheers,
Monkeythree
bmnelsc
ORIGINAL: jamieda
drop of oil on each exhaust manifold close to engine, only 3 burned off, cylinder 2 exhaust manifold the old spot stayed damp.
ORIGINAL: Monkeythree
What have you done to establish that it is no.2 which is not firing?
It can only be spark, fuel or compression so it seems that if you know no.2 is not working then you must have identified that one of these three things is missing in that cylinder. That being the case, you have diagnosed the problem and now only need to pinpoint the cause and then fix it.
Let us know how you concluded that it was no.2 and then we'll go from there.
Clever method for determining which cyl is not firing - I'll have to remember that one for future use.
bmnelsc
I wouldn't spend any more time with the engine running because if you have fuel but no spark in no.2 you will have put quite a volume of fuel into that cylinder by now which won't do your cylinder or oil any good. For any further troubleshooting on the ignition side, start by isolating the fuel pump so you are not washing the bores any more. You need to check which relay to pull to cut the fuel but still give you spark (might be the DME relay but not sure about this).
As per checking for fuel delivery to No 2 - can you pull injector from the manifold leaving it connected and put it into a jar or similar. Pull the coil wire and crank it to check for fuel delivery. I haven't fiddled with injectors/fuel rail on a 944 but running your injectors (one at a time) into a calibrated tube is described in the 924 (and several other makes) manuals to determine if your injectors are delivering sufficient volume. Might be worth a try.
jamieda
ORIGINAL: colin944
The car would run but just have no get up and go.
thats kind how it felt, just ran a compression test and all 4 cylinders showing 180 psi
inside the cylinder thats not firing is very wet compared to the others that are bone dry. (looked through the spark plug hole with a torch)
In answer to your question no i haven't changed the leads, changed everything else but not the leads, simply because i couldn't find anywhere local that had them in stock. going to order some now and see how i get on mid week if i have time.
if that doesn't work then its off to GT1 in Chertsey as really want to get it sorted for TIPEC Beaulieu weekend.
Fred Hindle
Maybe a good idea to change the rotor arm and the dizzy cap while you are about it unless they have been done recently.
Cheers,
