S2 lost power funny exhaust noise, Help
- Thread starter jamieda
Monkeythree
Or if you are feeling masochistic, simply take a firm grip of no.2 lead in your hand and have an accomplice turn the engine over. You will soon know if the spark is leaking out of the lead! [
(No liability accepted for death or injury if you are foolish enough to use the above method) [
jamieda
ORIGINAL: Monkeythree
Yep. Just borrowing a known good one from another cylinder will give you a pretty much instant answer as to whether no.2 lead is bad or not.
Or if you are feeling masochistic, simply take a firm grip of no.2 lead in your hand and have an accomplice turn the engine over. You will soon know if the spark is leaking out of the lead! []
(No liability accepted for death or injury if you are foolish enough to use the above method) []
jamieda
ORIGINAL: Fred Hindle
http://www.eurocarparts.com/ecp/c/Porsche_944_2.5_1988/b/Bosch/p/Car-Parts/Engine-Parts/ignition1/ignition-lead
Maybe a good idea to change the rotor arm and the dizzy cap while you are about it unless they have been done recently.
Cheers,
jamieda
(turns out its cylinder 3 not 2 DOH i was counting from the wrong end)
I put the lead from cylinder 4 into cylinder 3, cylinder 3 lead would not reach cylinder 4 (all the leads are the right length to fit each plug)
So i tried to start the car with just 1,2 and 3 attached, it wouldn't start at all?
Monkeythree
jamieda
Compression - https://youtu.be/zh3hm-f5D4c
Got spark and compression confirmed, piston head is wet but i guess this doesn't confirm fuel coming in. how do i do that?
Thanks for the help Monkey
Take the plug out of the suspect cylinder and plug it back into its suspect lead. Earth the body of the plug against a convenient earth (engine lifting eye is good). If necessary, secure the plug against the convenient earth with mole grips or similar. Turn the lights out. Turn the engine over and keep a close eye on the spark plug gap. You should be able to see a nice bright blue spark jumping across the gap. Report back what you find.
Monkeythree
So while you were doing that test on the suspect plug lead, did the engine sound the same or different to when it was running roughly but with all the plugs in and leads connected? (Sounds the same to me but would be good to know if you detected any difference).
If sparks are all good and compression all good it is starting to look like a fuelling issue.
Monkeythree
ORIGINAL: 944Scott
Did you revert back to using the plug lead from cylinder three when checking for spark or were you still using the plug lead from cylinder four ?
Very good point. It would be good to be certain of this before moving on. Jamie?
Monkeythree
jamieda
I bought this car to drive and fix, its my learn about cars car, both how to drive on track and fix, I've always wanted to learn about the mechanics of a car so i'm enjoying this.
ORIGINAL: Waylander
some one with a bit of mech know how must be close to you, come and give you hand
jamieda
Can i swap the electrical connections over from one injector to the next or is that running the timing?
I would start with a close visual examination of the injector wiring going to number 3 cylinder. Check for any signs of chafing of the insulation on the wires or any obvious kinks or tight turns that might have turned into a break.
Monkeythree
ORIGINAL: jamieda
I've got to say the bend in the wiring going to injector 3 is very tight but doesn't look broken.
You can't swap the injector wiring over because they are sequenced to the engine firing order.
The tight bend might not look broken from the outside. Get all your plugs and leads back on and start it up again and give the injector wiring a good massage along every part you can get your fingers and thumbs around and listen carefully. If there is break and you manage to get a contact whilst massaging the wires, that cylinder should kick back in again and you will surely hear the difference in the running.
jamieda
Surrey
ORIGINAL: 944Scott
For the record, where in the country are you located ?
jamieda
Thought so, ok will give that a go tomorrow when i get back from work.
Will report back.
cheers, really appreciate the knowlage
i have no problem chucking this in to a Porsche specilist to sort out but that would be cheating and defeat the object.......... so thanks again for your time.
