Schroth Harness
- Thread starter h_____
Hacki
Right, and be also careful with the buckles. In case someone has the old original blue buckle, don´t use it. There was a safety warning by Porsche in March 1993 (Porsche reference no. VKGB no / dz) that these buckles broke in accidents, because the bottom was not strong enough. They had to be replaced by black ones. It didn´t take long to have that done. This refers only to the original Schroth harnesses with a blue buckle as used in the early 90s. They were sold to anybody, Porsche used them as factory equipment. So the owners of cars with these buckles received that safety warning mentioned above by Porsche. Rgds HackiORIGINAL: Melv Don't want to **** on your day guys, but be careful with used belts.........
Sounds like a spectator sport Hugh......[ORIGINAL: h_____ Then reassembly (is the reverse of...no) is a case of putting all the springs back together, having a steady hand, and being deft with the screwdriver whilst still holding the whole thing together.
Full harness belts are quite legal for use on UK roads. Regards, CliveORIGINAL: h_____ Not sure about them being illegal for road use in the uk.
Hacki
Laurence, the twist rotate on my Cup car was road legal only for one reason : Porsche factory had a special permission (Regierungspräsidium Stuttgart, reference no. 27-415 Porsche 1 from 28th Dec. 1989) It´s the answer to Porsche´s request from 15.12.1989, Porsche reference no. EGG4 La-ka. That permission says that the belts don´t have to be officially labeled. It´s as simple as that in fact. It also includes a few more extra permissions to have a Cup car road legal. This permission mentioned above was limited for the 50 Cup cars of the first series. So every permission belongs to a certain vehicle and carries the individual VIN of that vehicle. Maybe there´s something similar for 964 RSs. A belt system of today that is road legal (ece labeled) and FIA labeled is Schroth Profi III-asm, either 4-point or 6-point. And it´s push button. Rgds HackiORIGINAL: Laurence Gibbs The issue with legality is i think more to do with them having e markings (under construction and use regs) very few(maybe none !) twist rotate belts have e markings and are listed as FIA compliant rather than ec compliant. Most ec belts are push button. I believe the road legal schroths are also push button. I don't know if the 64's and 93 clubbies had push button schroths or twist/ rotate as standard? People obviously do fit later belts too ! I remember dessies clubbie had push button schroth. Cup Cars would have twist rotate for FIA compliance i guess ?
Hacki
Cup cars had a single seat and Schroth 2 inch twist rotate belts (red straps and blue buckle). The blue buckle was replaced later by a black one which had a more solid bottom. The original stuff is old and belongs into the shelf. Replaced mine with 3 inch 6-point Schroth Profi III-asm, which is fine. Rgds HackiORIGINAL: Laurence Gibbs Cup Cars would have twist rotate for FIA compliance i guess ?
