Twinfan - have you tried just connecting it up with the croc clips directly to the battery under the bonnet? That would be my "Plan B" if I can't get the cigar lighter adapter to work. I'll let everyone know if I can find a way of feeding the wires out through gaps in the bodywork without having to leave the panel itself out when I try connecting mine up over the weekend.
Edited to add - I hadn't seen a couple of posts when I replied to this, there seems to be a fair bit of wiring with the kit overall, at least a metre and a half I would say between the panel and the connector for the Optimate and probably the same between the Optimate and the connector for the croc clips, so I would think there's enough length to reach the battery even with the panel inside the car. The only worry I'd have is leaving the connectors out in all weathers but mine do have rubber covers over the connecting plugs.
