Some Advice Please Guys & Gals, with this COVID19 and we cant drive
- Thread starter Nick7602
I think I had best stay off the cakes just in case!! [
Caroline, I have a similar problem with my late 50's single garage. I can just about get the car in with the mirrors deployed (no electric function on my 987.2) and then squeeze my 5'10" 10-stone frame out through the gap between door and wall. Easier to get in than extricate myself!
Jeff
To be fair it has taken quite a lot longer than I expected to charge the battery back up to full - I had naively assumed I would only need to leave the car out one or two days a week to charge it up and then be able to put it back in the garage for a couple of weeks in between. Given how sunny it has been the fact that it has taken about a week to get to this stage has surprised me a bit but then again I guess 20W isn't really a lot of power and I am guessing the Cayman battery is a pretty high power one. So to keep it conditioned it means I'll probably have to leave the car out permanently or semi-permanently whilst the lockdown remains in place (extended for another 3 weeks today). Once driving restrictions loosen up a bit and I can take it for longer runs, it will go back in the garage though, I just hate seeing it literally sitting there collecting dust and debris :-(
According to the spec for your 20W solar charger the max average charging current is 1.66A. Assuming you have an 80Ah battery (it may even be 100Ah for stop-start on your car?), even if it's half-charged to start with it would take 24-hours [40/1.66] of sunlight to charge fully in ideal conditions (100% charging efficiency), so even that could take three or even four days under real circumstances.
Don't forget that the battery doesn't have to be fully charged all the time. If the battery's in good condition, once fully charged you should still be able to leave it for a couple of weeks and still have sufficient cranking amps to start the car.
Jeff
At least if it does rain the dust will all get washed off the car! [
I'm not sure which models of Cayman the previous writers have but to check if the socket is live with ignition off, use the lighter, if it pops up after a few seconds then it is live and protected in the case of the 987's by a 10A fuse adequate for trickle charging and the way that the Porsche Charger ( A rebadged CTEK unit ) is recommended to be used as it has a plug fitted.
Voltage under charge should be greater than the voltage of the battery, I don't know why but it's the way they get a charge into them whatever current they are getting.
I've just plugged my solar panel setup back in with the panel inside the car on the dashboard in front of the steering wheel. I'm going to leave it like that now and hope that the panel can at least reduce the battery drain but hopefully it can keep it topped up now. We'll see how it goes this week!
I think if you want to maintain charge in all weathers with the panel inside the glass it's likely you really need the next size up (40W), even if the panel is in an ideal placement i.e. south facing and unshaded.
I'm going to continue with more of the same i.e. put the panel out in the sun or when it's dry but dull, and just have to hope we don't get too many rainy days between now and the end of the lockdown! [
While researching solar panels before I bought mine, there were plenty of comments across the internet that the cheaper 10-12w panels (which are not weather proof) were maintaining batteries so I'm personally not sure they have to be outside to work properly. What I think they do need is a full battery to start with, they need to be hooked up 24/7 to scavenge every last bit of light and that they're not really able to charge a low battery. They're definitely more for maintenance. So they may suit my needs/use more than yours?
Twinfan said:Thanks for the info Caroline. My car is South facing and has had the panel inside the car for 3 days now. I checked it last night and I'm still getting the "double flash green" indicator which means the battery is still fully charged. The true test will be in a week or so as I would have expected some drain by then, so I'll see how it goes.
Thanks Twinfan that's interesting. It might just be because it was dull/raining as well as the panel being inside, although as my car is East facing I don't think 100% of the panel gets the light when it's inside as it is balanced on the steering wheel and the back of the seat so the shadow of the roof covers part of it at times. It has however, when the panel has been out, charged the battery fully (it was originally on red in monitor mode), so I think it is capable of doing that, but in my situation it has to be outside the car.
I might leave the panel inside the car over the next few days, which are forecast to be sunny here, as an experiment to see if it maintains the battery at green.
However (much as I hate my beloved car being out in all weathers [
I guess the other option is to try to jerry-rig some sort of harness for the panel inside the car so it can sit closer to the window but as it's not much of an inconvenience to go out and put the panel on the roof in the morning and back inside at night I haven't tried that yet! (translation = I've been too lazy to bother! [
AndrewCS
My older model C-TEK XS800 has a charge rate 0.8A, took a week to recover a dead flat battery - was well pleased with that.
Hadn't realised that even some of the mains chargers took a long time to charge, I am guessing then that this is deliberate, i.e. maybe a very fast charge rate might damage the battery?
Twinfan said:My car is South facing and has had the panel inside the car for 3 days now. I checked it last night and I'm still getting the "double flash green" indicator which means the battery is still fully charged. The true test will be in a week or so as I would have expected some drain by then, so I'll see how it goes.
Well 10 days on and I've still got a double-flash green light (91-100% charge indicator). I guess the panel is working [
Interestingly I've noticed that it is always in "maintain" mode (green LED) when it first starts charging in the morning, but seems to go into "charge" (yellow LED) mode by the late afternoon/early evening. However either way when the sun has gone down it is still always showing as a double-flashing green LED in the monitor mode, so I am also assuming it's working and keeping the charge maintained now.
I am wondering whether this is what Optimate mains chargers also do when they are maintaining the battery, i.e. is there some sort of daily maintain/charge cycle they work to anyway?
