Spares Listings
- Thread starter John Sims
Tam Lin
ORIGINAL: Tam Lin
If anyone has an LSD'd S2/Turbo gearbox knocking around, I could use it for my 924S project []..
Also, in readiness for this year's projects, I have FOR SALE:
1) Plastics for Performance lexan hatch, fitted to standard 944 frame/plastic spolier. About 14 Kg lighter than the glass thing. Wanted in the region of £270
2) Pale Gray (Porsche speak: Linen) Leather Doorcards for early 944/924S. Yes, I mean leather. £80
bazbarnett
Hello all..
I'm looking for 2 gas bonnett struts for my '82 944 Lux, also a brown luggage blind as the spring's gone on mine!
Anyone help me?
Baz
Anyone help me?
Baz
pauljmcnulty
ORIGINAL: bazbarnett
Hello all..
Anyone help me?
Baz
Bonnet struts are a standard part, see the faqs for suppliers. Be careful fitting them, don't be tempted to push the bonnet up as you'll crack the windscreen.
Luggage covers are one of those things that you'll find if you browse e-bay for a while. You might get lucky, but it could be a case of being patient! [
I have a Dynatech strut brace for sale for 944/951 (year 85-91) in used excellent condition. This is a quality handmade product with best workmanship and materials which costs me £300+ when I imported it from the US a couple years ago. Dynatech has stopped making it now so it it also a very collectable item for 944/951 owner. I am currently selling it on ebay so if you want to make me an offer before the auction ends, please do.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150426089760&ssPageName=STRK:MESELX:IT
Check out the Dynatech strut brace yourself ...
http://www.dynatechmotorsports.net/suspensions/strut_brace.htm
Hi All
Im looking for fuel rail for an early car, with both regulators at the back. However I have seen 2 different ones like that, noidea what the other one fits,mine has no other metal pipes screwed to it, the flexies go straight on to it.
Any ideas.......
Mike
Any ideas.......
Mike
shaynan944
chrisg
For Sale:
1 x pair of Mintex 1155 Brake pads will fit Front and rear of early 220 Turbo or S2 or just the rear of the 250 Turbo.
I had them in the rear of my 951 for ~ 300 miles but because of a warped disc and slightly off retaining clip they rattled too much so took them out and replaced them with standar pagid pads.
Any offers over £35 ?
Yours
Chris
Yours
Chris
Can anyone help with:
Clock
Slider knobs for the heater
The round aircon vent thing (next to the clock)
Screw covers for the A-pillars
Screw covers for the sunroof middle thing
Centre console (part that the stereo is in and go's around gear knob)
Gear knob gaiter
Arm rest
Cig lighter
Driver & passenger cill trim that holds the carpet down
Boot lock seal
Boot carpet
Rear seat back clips that hold the carpet to the seats
Rear roof trim
C-pillar trim
Clock
Gear knob gaiter
Arm rest
Cig lighter
Boot lock seal
Boot carpet
Rear roof trim
C-pillar trim
OK...
I have...
A complete kit of parts for air-con for an early dash 944 - wasn't working, and don't know why not, but did find a broken wire on the pressure sensor, which was the problem when I started investigating it. £250 and I'll probably regret it. I mean complete, loom, compressor bracket, correct heater assembly, etc, etc.
A set of logo cloth seats - vinyl bolsters,all electrics work (2way electric) from my S2. some wear on drivers side bolsters.
Manual rack and cross-member for those that are fed up with power steering woes!!!
I need...
Front brake calipers for an S2, Nearside specifically, but a pair might be nice depending upon functional condition - cosmetics not that important, a little plate lift maybe ok... For use on my day-to-day snotter.
Exhaust for the same - I am weighing up putting a new system on for the lack of hassle, but if some-one has something at the right price... No cat.
Tyres - I use those Pirellis that every-one hates, but before I shell out another £220 for a set of rears, if some-one has a pair that they really, really hate, and stupid amounts of tread left, I will pay reasonable money towards putting on something you prefer. 16" x what-ever the stock S2 size is...
Tref.
I have...
I need...
Tref.
You have mail.
pauljmcnulty
Looking for a steering column coupling, the bit under the bonnet with a u/j on each end.
'88 944 Lux, power steering.
Cheers.
Last one I bought was only about £70 new IIRC. Used one is likely to be worn, and then you've got all the labour again.
ORIGINAL: sulzeruk
Am gutting the underside of an S2 at the mo so have a gearbox, bottom end of the engine, power steering bits and bobs, etc up for sale.
Also have a good S and and S2 cylinder head. Mint cams for the S, no cams for the S2 though.
Alasdair
I'm looking for an S2 crankshaft.
Still need some of this if anyone can help [
Also after:
Clear trim behind heater controls
Trim around clock
Sport seats in black leather
I have some 89' rear 1/4 cards with the stereo upgrade cover in need of a little TLC for sale.
And 88' Lux inlet maifold with fuel rail, inj, fuel regs, AFM and TPS for sale.
ORIGINAL: homesea
Clock - Sorted
Slider knobs for the heater -Needed
The round aircon vent thing (next to the clock) -Needed
Screw covers for the A-pillars -Needed
Screw covers for the sunroof middle thing -Needed
Centre console (part that the stereo is in and go's around gear knob) -Needed
Gear knob gaiter - Sorted
Arm rest - Sorted
Cig lighter -Needed
Driver & passenger cill trim that holds the carpet down -Needed
Boot lock seal - Sorted
Boot carpet -Needed
Rear seat back clips that hold the carpet to the seats -Needed
Rear roof trim -Needed
C-pillar trim - Sorted
Also after:
Trim around clock
