Steering Wheel
- Thread starter lali
I recently visited a scrap yard whhich had a Momo Champion steering wheel and boss for sale £100 squid all in, well possibly a like more if you want it posted to you, in excelent nick !
C.M.S. PORSCHE 01952 243 924 ; Mobile 07831 711 609 -
Unit 2 Ketley Business Park
Telford TF1 5JD
if your interested
Marc[]
berg944
The splines are the same but they have different lugs for the indicator cancel.
Sorry, cant remember if you can change the lugs over.
Warning......If you put a post 85 boss with a metal lug on a pre 85 car it will go on fire the first time you turn the wheel......I know[]
Mike[:'(]
random hero
cococola
ORIGINAL: random hero
I tried this wheel on my oval dash car but it sits proud and doesnt cancel the indacators so im selling it .A guy wants to know if it will fit his 928 i think it will but in not 100% sure and i dont want to set his car on fire !!
Reverse the process to get the new wheel on. Try to get the new wheel on at the 12'o'clock position. You should only be one spline out of dead centre at most. Make sure that you fit the big washer between the wheel and the nut. Get someone to assist holding the wheel to ensure that you get the nut tight. This is critical stage for safety.
Warning: do not attempt any of this whilst driving!
Enjoy your new steering wheel!
(I'm asking because Porsche-listed bosses sell for lots on eBay, but Golf ones are much more common and thus much cheaper!)
mik_ok
The main retaining nut is 24mm and you need quite a long reach socket. Rather than try and hold the wheel with my knees whilst loosening the nut I used a bar (as opposed to a ratchet) and tapped it with a hammer ~ it's not under massive load so moved easily.
Careful with the horn contact on the stalks - if you knock it off line it'll grate every time you turn the wheel.
Link to thread when I fitted my Momo Fighter Clik
Fred Hindle
(Not going to swear to it but I think the nut on mine was 22mm).
Be careful when using the hammer to dislodge the wheel. (Use a rubber mallet is best).
First time I removed the steering wheel on the 944 I hit it hard with the mallet, managed to prevent it hitting the roof lining by putting my nose in the way. After That I only use light blows and keep the other hand on the centre of the wheel to prevent it happening again.
Another way to check that the steering wheel is aligned correctly is to drive down the road slowly with the nut just finger tight. Stop , re-adjust wheel and set off again. When happy with position tighten up the nut with a socket.
Cheers,
But if the wheel is central (to within one spline)then how can I correct this???
Fred Hindle
Cheers,
Fred - The Mk1 and early Mk2 Golfs had the same fitting, it changed in around 1988 from a smaller shaft to a larger one. Which is about the time that the 944 changed from the square dash to the oval dash. Also, in this thread on the Club GTi website:
http://clubgti.com/forum/showthread.php?t=22714&highlight=968+wheel
... there is a chap who claims to have fitted a Porsche 968 steering wheel to his Golf. Both those pictured in his signature look like later cars (hence large shaft), and I am trying to make contact with him to find out more ...
Therefore, I *suspect* that the oval-dash 944 is the later Golf fitting. And, to this end, I am bidding on a late Golf steering boss on eBay. I'll keep you all posted!
