Steve WOng Chip
- Thread starter Guest
IanHighfield
I went to Weltmeister for a pre dyno, sent the AFR by e-mail, and had the chip in no time.
Tip - fully raise the electric seat to ease access to the DME (ask how I know !!!).
Good luck and lets have some before and after dyno prints.
Can you contact Steve Wong directly so that he can process your order.
Alan - understand you already have. Thanks [
I've given the other guys details as per e-mails I have received directly: Mike Wood & Nigel Peckham
Mike, Nigel - Steve will wait for you to contact him directly to place your order. Once all complete he will process all four.
I'd appreciate it if you could contact him soon (eager to get my chip [
IanHighfield
John Glynn over on ImpactBumpers.com is setting up a dyno day - worth taking a look and seeing when it is.
I've given Steve my payment details. Here's the latest from him this morning:
'So far the minimum has been met, so the group buy is valid - will await
Nigel's order.'
I need to provide Steve with some additional details of my ecu, but as Steve's got the min of 3 orders this shouldn't hold up anything. I'm aiming to email Steve when I get hole and can get what he needs off the car.
I have some Recaro Pole position seats and it is not possible to slide the runners far enough back so unbolting the seat was the only option.
Once the motronic unit is removed the instructions are very good and the most difficult task was undoing the little tabs which can only be likened to the tabs you get on the back of a picture frame.They are a little fragile so be careful not to bend them to far back.
Have filled up with optimax today and can honestly say the car feels so much more willing, should have bought one 2 years ago.
I also changed the fuel setting and this was easily done by using a small screw driver in the triangular slot.
Should you need to email me please feel free to do so on my link in the members area.
Alan
ashrolfe
The main benefit from the chip seems to be it eagerness to rev in all gears wheras before it felt a bit flat. I am going on the impact bumpers dyno day on the 16th sept so will report the actual increase in HP.
Alan
