robwright
Yes the board is a fine example of where Porsche used wood to build your car. It sits under the carpet under the passengers feat. Under it is a metal frame containing the DME (ECU) and also the KLR (Knock detection) if you have a turbo. The modules could be loose on the frame or even the frame on the chassis. I doubt the plywood cover could make such noises but that too bolts onto the chassis. The metal frame should have plastic spacer fasteners at the top to secure it. Check that you have these and it isn't just rattling around.
