Strange noise
- Thread starter Logie
Bleed the power steering by turning the wheels from lock to lock a few times with the engine running, then check the fluid level again maybe.
ORIGINAL: markmsa
yep checked the fluid level hot and cold and its fine, is the abs pump on this side could it be that as the warning light is on but I put that down to a sensor?
Now you didn't mention the abs light.........
That's probs what it is although I would reckon you would be able to feel the abs working through the pedal when you touch the brake.Put your ear just below the side repeater indicator on the drivers side wing and you will be able to hear the abs pimp is it is running.
I've changed the pump on both cars I've had to repair the ABS. The last one needed a couple of sensors as well but this one just needed a new(er) pump and all is well. I gave it a very liberal coating of Dynax too in a hope of preventing it from going bad.
Make sure that you have a ratchet spanner and a brake-line spanner to get the nuts loose first without rounding them off. You'll need to bleed the brakes afterwards as well.
The reason they fail is that they get corroded and the surface can be seen to physically blister. If the used one looks good then it will most likely be good - there are various checks to make sure that it is the pump that's the problem though, here's a good place to start:
http://m.rennlist.com/rennforums/showthread.php?t=272248
Monkeythree
CV joint?
I'm assuming these are all new on your car so shouldn't be doubted but if there's a noise, there's a noise!
Kongsodoken
starnge that the noise is intermittent and very loud .....but only lasts for a few minutes and doesn't come back till every thing has cooled then warmed up
Monkeythree
Kongsodoken said:Yes new OEM bearings. The cv joints are not new but greased and they looked OK
Are the CV joints correctly orientated? There is a circumferential groove. I can't remember whether the groove should be towards the outside or the inside without checking but a starting point would be to check that the left side mirrors the right. I can stick my head under mine tomorrow and check if you want.
peanut
if you coast round the bend in neutral you'll eliminate the engine or transmission being the source of the problem.
Kongsodoken
ready with the phone to record the noise
