Strut braces
- Thread starter appletonn
Peter Empson
I'm planning on looking at this more seriously sometime later this year as I'm convinved it should make a really big difference on a stiff car.
RSBarn
B&K
ORIGINAL: Neil Haughey
I have the KLA strut brace. TBH I didn't notice much difference at first but then I adjusted the bar to tighten it up. Wow what a difference. Setting preload is key to me without it, it doesn't seem to do much. The steering is way sharper and very accurate.
BTW I also have the KLA solid top mounts and personally I can't see much point in fitting a strut brace to a car with big rubber top mounts.
Rear suspension flops around all over the place because of the torsion bar tube mounts and torsion bar end cap bushes. I only have the Weltmeister end cap bushes but AFAIK Fen had or has a complete set. These make a huge difference, basically with the stiffer bushes you can get straight on the throttle after turn in, without you have to wait for the car to settle. With the stiff bushes the car just tracks through corners where you point it and you don't need to make corrections unless you get a slide on (or plain cock it up).
I noticed a big change with these parts on a car with 220 Lb springing and Koni's. You guys with KW and 300+ Lb springs will see a night and day improvement. Where is Fen when you need him?
Neil
If you want to tighten the rear end up you could always go the same route as me http://www.kokeln.com/rear_suspension_kit.php This gets rid of the torsion bars so you need to get some coilovers and the racers edge bottom mounts. Doesn't half tighten the back end up!!! And saves about 25lb too!!!
Neil Haughey
Have to say I spotted the Kokeln set up a few years back and always looked like a fantastic option for anyone who is super serious about tracking their 951, probably a bit to extreme for me S2. I might even go back to stock bushings on the rear and use my Elephant racing bushes and weltmeister mounts (still in packaging) on something else.....
....maybe with a turbo.
Then I could drive pork all the time and never have to sully my rear in non-pork cars again.
Neil Haughey
ORIGINAL: John Sims
So in summary - a strut brace is a good thing. I am a bit concerned about sugestions of preloading the brace though. I agree that it should have enough tension that it isn't slack on the mountings but I would be cautious in tightening it above that.
Agreed, on mine I just spun it round perhaps 1 turn with my hands to take up any slack. I doubt I put much torque into it since you can't get enough grip on the bar with your hands. The difference was immediately noticeable when I then took the car out again for a post adjustment drive. Anyone who has an adjustable strut brace can do the same and "feel the difference" as they say.
TBH I just stumbled onto this becasue there wasn't anything with the bar to say it should be pre-loaded either inwards or outwards.
Hilux
I am sure they will be welded in studs,not splined force fit
I`d put money on it......................not a lot mind but money none the less
sawood12
ORIGINAL: sawood12
You can also get lower braces that attach via the castor mounts. From reports i've read these things are very effective.
There is a chap on a 968 forum who has had some made for his 968 cab. He reckons it has almost irradicated the scuttleshake. However I didn't like his design as it simply bolted onto the end of the castor bolts - i.e. the bolt that attaches the wishbone through the castor mount. I reckon the forces going through the bolt would change your castor angle.
The better ones, like the B&K one that Peter mentioned, actually attach directly to the sub-frame on the car itself where the castor mount attaches therefore raising the castor block up significantly which is why you need a re-alignment after installation.
ORIGINAL: appletonn
Having had a look at some top mounts and spoken to one of the Oracles, I now have it on good authority (thanks John @ Unit 11!) that the studs are splined interference fit, so may be knocked out with some brute force and ignorance and replaced with longer bolts.
Nick
I thought they were welded, but its a while since I looked at them. I have the KLA brace and just used thin stainless washers. I then later fitted the KLA fixed top mounts. I think the spherical bearings in the top mounts may be knackered though anyone got a set off the car? they dissasemble easily and they should be easy enough to source if I knew the size,
Tony
sawood12
appletonn
By using super thin washers in place of the originals and being very careful with the torque wrench ([8D]), I now have the 2 strut brace brackets fitted and there was just enough thread showing to torque everything down nice and safely - top thread of stud just peeping out over top of nuts once tight...
Phew, that's saved me a lot of faffing around[
Nick
steve 944t
But if you havent, check check and treble check that there is enough clearance when you do shut the bonnet. It really is very tight.
appletonn
Actually used some BluTack on top of the brackets and gently closed the bonnet and then checked to see if any indentations...!
Thanks again
Diver944
Nowadays I would be more scientific and use my G-Tech accelerometer that can measure later G (but I would need to wear my new anorak at the same time
Neil Haughey
Peter Empson
To bring it back on topic, I too noticed an unsubtle difference just on a roundabout test, this was with the KLA bar. It resulted in an improvement in feel on turn and its ability to track the chosen line.
