Strut braces
- Thread starter appletonn
appletonn
where is this extra bracing you mention? Mine is a March '91 registered car, but I cannot see anything different under the bonnet to some of the earlier cars I looked at before buying mine?
I'm obviously not looking in the right places...!
I was hoping to take it for a long drive this weekend to see if i can detect any difference with the strut brace, but I think a submarine is more appropriate, looking at the forecasts!
Peter Empson
I haven't got the picture here, but as I remember it, it is a vertical piece of steel that effectively triangulates onto the chassis legs, I described it as coming from the bulkhead previously but suspect it might actually be attached to the front wheel arch area.
I'll see if I can find some more details and post them later.
Tony
Hilux
there was just enough thread showing to torque everything down nice and safely - top thread of stud just peeping out over top of nuts once tight...
Careful...................
It is generally accepted that 2.5 - 3 threads need to protrude past a nut for it to be considered `safe`
If a nut loosens after tightening (and they can `relax` hence always check bolts after a time as they are done up at a temperature which then fluctuates) it might run past the available thread. Once it does it accelerates the unfastening.
I`d be inclined to install longer bolts/studs every time. As a minimum, dot punch the top thread. The nut will `cut` its way off as required but the stud/bolt will be reusable.
Peter Empson
appletonn
I will probably dot punch the top thread though......
Just to be on the safe side....
Not that I'm worrying or anything....!
TTM
Well-known member
ORIGINAL: 944Turbo
Yes, I was told they were added to silver roses only but then opened my bonnet and they obviously were not.
Strange. Perhaps then they were regular fitment on late T250 and cabs LHD only ?
What year is Simon's car ?
Neil Haughey
ORIGINAL: 944Turbo
ORIGINAL: appletonn
Having had a look at some top mounts and spoken to one of the Oracles, I now have it on good authority (thanks John @ Unit 11!) that the studs are splined interference fit, so may be knocked out with some brute force and ignorance and replaced with longer bolts.
Nick
I thought they were welded, but its a while since I looked at them. I have the KLA brace and just used thin stainless washers. I then later fitted the KLA fixed top mounts. I think the spherical bearings in the top mounts may be knackered though anyone got a set off the car? they dissasemble easily and they should be easy enough to source if I knew the size,
Tony
Just bought a new set of top mounts from ESS as I dont have time to remove and source the sphericals at the moment, the new ones are much better quality than the originals which were direct from the US before Simon started selling them,
Tony
